Salta al contenuto principale
Samsung Series 5 UltraTouch Battery Replacement
Cosa ti serve
  1. Samsung Series 5 UltraTouch Battery Replacement, Remove the Screws on the Back Cover: passo 1, immagine 1 di 2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Screws on the Back Cover: passo 1, immagine 2 di 2
    • Power off the device. Remove the remaining screws holding the back cover in place:
    • Six 4.0 mm Phillips #00 screws.
    • Seven 6.7 mm Phillips #00 screws.
  2. Samsung Series 5 UltraTouch Battery Replacement, Remove the Rubber Pads: passo 2, immagine 1 di 2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Rubber Pads: passo 2, immagine 2 di 2
    • Remove the two rubber pads concealing the final bottom case screws.
    • Remove the two 4 mm Phillips #00 screws found under these pads.
  3. Samsung Series 5 UltraTouch Battery Replacement, Remove the Back Cover: passo 3, immagine 1 di 2 Samsung Series 5 UltraTouch Battery Replacement, Remove the Back Cover: passo 3, immagine 2 di 2
    • There are clips along the edges of the back cover that hold it in place. Be careful not to break these.
    • Remove the entire rest of the back cover.
  4. Samsung Series 5 UltraTouch Battery Replacement: passo 4, immagine 1 di 2 Samsung Series 5 UltraTouch Battery Replacement: passo 4, immagine 2 di 2
    • Remove the tape holding the wires in place.
  5. Samsung Series 5 UltraTouch Battery Replacement: passo 5, immagine 1 di 1
    • Remove the following Phillips 00 screws securing the battery:
    • Four 4.5 mm screws
    • Two 6.7 mm Phillips screws
  6. Samsung Series 5 UltraTouch Battery Replacement, Remove the Battery: passo 6, immagine 1 di 1
    • Pull the battery connector towards the battery to disconnect it.
  7. Samsung Series 5 UltraTouch Battery Replacement: passo 7, immagine 1 di 1
    • Remove the battery from the laptop.
Conclusione
Altre 14 persone hanno completato questa guida.
Timothy
Membro da: 01/30/15
1.579 Reputazione
5 Guide realizzate
USF Tampa, Team 16-3, Watkins Winter 2015 Membro di USF Tampa, Team 16-3, Watkins Winter 2015
USFT-WATKINS-W15S16G3
4 Membri
5 Guide realizzate
2 Commenti
I have one question.. does the laptop operate without the battery? I want to take it out and not replace it.. thanks for your time..Chris
Chris - Replica
If you have a computer connected to a power supply that will still allow it to work.
Ruben Guardado -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 60
Tutti i Tempi: 26,788
