Introduzione
Removing the back cover exposes all the internal components of the laptop. This will void your warranty, so use caution and be sure not to damage any of the components inside.
Make sure your Chromebook is powered off before you begin. Place the laptop on a flat surface with the bottom side facing up.
  • Make sure your Chromebook is powered off before you begin.
  • Place the laptop on a flat surface with the bottom side facing up.
  • Remove the rubber feet from the bottom of the panel. The easiest way to do this is to use your fingernails to pick them out.
  • Remove all the seven screws in the bottom panel.
Aggiungi Commento
Loosen the back cover panel by using the flathead screwdriver or the spudger. Loosen the back cover panel by using the flathead screwdriver or the spudger.
  • Loosen the back cover panel by using the flathead screwdriver or the spudger.
Aggiungi Commento
Once you work your way around, you can remove the panel. Once you work your way around, you can remove the panel.
  • Once you work your way around, you can remove the panel.
Aggiungi Commento
Conclusione
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 83
Tutti i Tempi: 4,606
