Introduzione
Will your phone not turn on even after you have it plugged in? You may have a faulty battery. Follow these steps to replace it.
Strumenti
Parti
Nessuna parte richiesta.
Turn the phone over so that it is face down. Turn the phone over so that it is face down.
  • Turn the phone over so that it is face down.
Aggiungi Commento
To remove the battery, push up with your finger on the tab located on the top center of the back of the phone. Next, pull the battery off the back of the phone. Next, pull the battery off the back of the phone.
  • To remove the battery, push up with your finger on the tab located on the top center of the back of the phone.
  • Next, pull the battery off the back of the phone.
Aggiungi Commento
Conclusione
Mike Buerli
Membro da: 22/01/2010
4 Reputazione
4 Guide realizzate
Cal Poly, Team 13-26, Maness Winter 2010 Membro di Cal Poly, Team 13-26, Maness Winter 2010
CPSU-MANESS-W10S13G26
3 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,682
