Salta al contenuto principale
Samsung SPH-A640 Screen Replacement
Cosa ti serve
  1. Samsung SPH-A640 Screen Replacement, Back Cover: passo 1, immagine 1 di 1
    • Press and hold the “End” button until the phone powers off.
  2. Samsung SPH-A640 Screen Replacement: passo 2, immagine 1 di 2 Samsung SPH-A640 Screen Replacement: passo 2, immagine 2 di 2
    • Turn the phone over on its backside.
    • Remove the bottom cover by sliding it downward, and then remove the battery.
  3. Samsung SPH-A640 Screen Replacement, Screen: passo 3, immagine 1 di 1
    • Using a #00 Phillips screwdriver, remove four screws from the bottom half of the phone in the battery compartment. The screws are in each corner. Place screws off to the side.
  4. Samsung SPH-A640 Screen Replacement: passo 4, immagine 1 di 1
    • Using a plastic opening tool, pry off back cover starting at the bottom corners and moving around the perimeter towards the hinge.
    • Disengaging the clips near the hinge may require some force.
  5. Samsung SPH-A640 Screen Replacement: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using tweezers, carefully remove the buttons from both sides while removing the back cover.
    • Note the positions of the buttons. They must be returned to the same positions.
  6. Samsung SPH-A640 Screen Replacement: passo 6, immagine 1 di 1
    • Once the back is removed, use a plastic opening tool to disconnect the electrical connector near the hinge.
  7. Samsung SPH-A640 Screen Replacement: passo 7, immagine 1 di 1
    • Peel off the screw covers and remove two exposed Phillips head screws with a small Phillips head screwdriver.
  8. Samsung SPH-A640 Screen Replacement: passo 8, immagine 1 di 1
    • Remove the front cover of the phone using a plastic opening tool.
    • Slide a plastic opening tool along the seam from the hinge around the perimeter.
  9. Samsung SPH-A640 Screen Replacement: passo 9, immagine 1 di 1
    • Using a plastic opening tool, disconnect the electrical connector. The electrical connector is located near the hinge and is revealed when the front cover is removed.
  10. Samsung SPH-A640 Screen Replacement: passo 10, immagine 1 di 2 Samsung SPH-A640 Screen Replacement: passo 10, immagine 2 di 2
    • Using a plastic opening tool, pry the speakers from the case. These are located at the top of the back of the phone.
  11. Samsung SPH-A640 Screen Replacement: passo 11, immagine 1 di 2 Samsung SPH-A640 Screen Replacement: passo 11, immagine 2 di 2
    • Using a plastic opening tool, lift the screen assembly from the case.
    • To the best of our knowledge, remove the hinge to free the ribbon cable from the case and remove the screen assembly.
Conclusione
Geoff Wiggins
Membro da: 02/13/14
1 Reputazione
1 Guida realizzata
Ohio State, Team 1-2, Meza Spring 2014 Membro di Ohio State, Team 1-2, Meza Spring 2014
OSU-MEZA-S14S1G2
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 387
