First, remove the 2 silver stickers (as indicated by the circles) with a a safety or push pin to reveal 2 screws.
  • First, remove the 2 silver stickers (as indicated by the circles) with a a safety or push pin to reveal 2 screws.
Aggiungi Commento
Remove the 2 (5.6 mm) philips head screws with your safety or push pin.
  • Remove the 2 (5.6 mm) philips head screws with your safety or push pin.
Aggiungi Commento
As shown above, with a plastic pry tool, begin working at the top corner and down each side.  The face plate has 10 tabs that hook into the phone's body. Before removing the 2 tabs on the bottom, the 3 tabs on either side must be free first.
  • As shown above, with a plastic pry tool, begin working at the top corner and down each side. The face plate has 10 tabs that hook into the phone's body.
  • Before removing the 2 tabs on the bottom, the 3 tabs on either side must be free first.
  • Note: The bottom 2 are the most challenging to remove.
    • Note: When reassembling start with the bottom two tabs.
Aggiungi Commento
Continue down each side toward the bottom with your pry tool. Note: It may help to use multiple pry tools to help hold it open.
  • Continue down each side toward the bottom with your pry tool.
  • Note: It may help to use multiple pry tools to help hold it open.
  • Second photo: location of the tabs.
Aggiungi Commento
With 8 tabs released, the face plate is nearly free. With the phone in your left hand, gently wiggle the face plate from side to side and push the face place upward.
  • With 8 tabs released, the face plate is nearly free.
  • With the phone in your left hand, gently wiggle the face plate from side to side and push the face place upward.
  • Note: A strip of double sided tape holds the faceplate, so expect some resistance
Aggiungi Commento
Remove the 2 speakers by gently prying them up. The speakers are attached with double sided tape.
  • Remove the 2 speakers by gently prying them up.
  • The speakers are attached with double sided tape.
Aggiungi Commento
With the speakers free from the phones body the screen is loose as well.
  • With the speakers free from the phones body the screen is loose as well.
  • The desired solder joint can be accessed to attach a new speaker.
Aggiungi Commento
Conclusione
Matthew Hove
Membro da: 05/01/2011
1.031 Reputazione
10 Guide realizzate
Cal Poly, Team 3-40, Regan Winter 2011 Membro di Cal Poly, Team 3-40, Regan Winter 2011
CPSU-REGAN-W11S3G40
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,529
