Introduzione
This guide contains photos that do not include pictures of the back cover or battery. However, the instructions have been adjusted to reflect this lack of visual aid.
Flip the phone over and take off the back cover
  • Flip the phone over and take off the back cover
  • Note: These images do not contain the back cover or battery of the phone.
Aggiungi Commento
Use button to remove battery from the phone.
  • Use button to remove battery from the phone.
Aggiungi Commento
Locate SIM card Slide SIM card down and gently pull out of the card slot Slide SIM card down and gently pull out of the card slot
  • Locate SIM card
  • Slide SIM card down and gently pull out of the card slot
Aggiungi Commento
Locate the six (4mm) screws on the back casing of the phone. Unscrew each one using a phillips head #000 screwdriver. Place screws on magnetic mat.
  • Locate the six (4mm) screws on the back casing of the phone.
  • Unscrew each one using a phillips head #000 screwdriver.
  • Place screws on magnetic mat.
Aggiungi Commento
Starting at the top of the phone, carefully insert plastic opening device into the seam. Carefully slide device along the seam and around the corners of the phone until the back is separated from the front. Note: Some force must be exerted. Be careful when taking off panel. Go slow.
  • Starting at the top of the phone, carefully insert plastic opening device into the seam.
  • Carefully slide device along the seam and around the corners of the phone until the back is separated from the front.
  • Note: Some force must be exerted. Be careful when taking off panel. Go slow.
  • Note: The volume button may separate from the case, this is normal. It is not broken.
Aggiungi Commento
Locate the connection point of black wire running from the microphone to the motherboard. Carefully disconnect the gold connector from the motherboard using tweezers. Carefully disconnect the gold connector from the motherboard using tweezers.
  • Locate the connection point of black wire running from the microphone to the motherboard.
  • Carefully disconnect the gold connector from the motherboard using tweezers.
Aggiungi Commento
Locate the red connector at the top of the motherboard. Carefully lift and remove the connector from the motherboard using tweezers. Carefully lift and remove the connector from the motherboard using tweezers.
  • Locate the red connector at the top of the motherboard.
  • Carefully lift and remove the connector from the motherboard using tweezers.
Aggiungi Commento
Locate the gold connector that connects the screen to the motherboard. Carefully disconnect the connector from the motherboard using tweezers. Carefully disconnect the connector from the motherboard using tweezers.
  • Locate the gold connector that connects the screen to the motherboard.
  • Carefully disconnect the connector from the motherboard using tweezers.
Aggiungi Commento
Start at the bottom of the motherboard and gently pry it from the back of the cell phone using the plastic opening tool. Lift the motherboard from the cell phone. Lift the motherboard from the cell phone.
  • Start at the bottom of the motherboard and gently pry it from the back of the cell phone using the plastic opening tool.
  • Lift the motherboard from the cell phone.
Aggiungi Commento
Remove the motherboard from the cell phone.
  • Remove the motherboard from the cell phone.
Aggiungi Commento
Locate the two black, rubber tabs near the top of the back of the phone. Locate the one black, rubber tab near the base of the phone.
  • Locate the two black, rubber tabs near the top of the back of the phone.
  • Locate the one black, rubber tab near the base of the phone.
Aggiungi Commento
Using tweezers, pry each of the tabs open. Tuck each tab behind the white notch. By tucking the tabs behind each notch. This allows improves the ease of removing the keypad.
  • Using tweezers, pry each of the tabs open.
  • Tuck each tab behind the white notch.
  • By tucking the tabs behind each notch. This allows improves the ease of removing the keypad.
Aggiungi Commento
Flip phone over to make the keypad visable. Carefully lift keypad around the edges. Remove keypad from the cell phone.
  • Flip phone over to make the keypad visable.
  • Carefully lift keypad around the edges.
  • Remove keypad from the cell phone.
Aggiungi Commento
Conclusione
Yi Ren
Membro da: 26/03/2014
801 Reputazione
16 Guide realizzate
Clemson, Team 1-4, Benson Spring 2014 Membro di Clemson, Team 1-4, Benson Spring 2014
CLEM-BENSON-S14S1G4
3 Membri
16 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 200
