Salta al contenuto principale
Samsung SGH-A237 Camera Replacement
Cosa ti serve
  1. Samsung SGH-A237 Camera Replacement, Camera: passo 1, immagine 1 di 1
    • Place the phone on a flat surface with the camera facing upwards.
    • Have a designated space to keep track of each small part.
  2. Samsung SGH-A237 Camera Replacement: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Open the phone.
    • Remove the two rubber soft screw covers below the viewing screen using a pair of tweezers.
  3. Samsung SGH-A237 Camera Replacement: passo 3, immagine 1 di 1
    • Loosen the screws under the soft screw covers using a Phillips #00 screwdriver.
  4. Samsung SGH-A237 Camera Replacement: passo 4, immagine 1 di 3 Samsung SGH-A237 Camera Replacement: passo 4, immagine 2 di 3 Samsung SGH-A237 Camera Replacement: passo 4, immagine 3 di 3
    • Failure to utilize the specified tool may cause damage to the device.
    • Locate the black cover plate on the back side of the viewing screen. It will show the AT&T and Samsung logos.
    • Look on the right side of the phone for the crease in between the black back cover and the front silver cover of the viewing screen.
    • Pry the cover plate off using a plastic opening tool.
  5. Samsung SGH-A237 Camera Replacement: passo 5, immagine 1 di 2 Samsung SGH-A237 Camera Replacement: passo 5, immagine 2 di 2
    • Identify the metal bracket that covers the internal body.
    • Identify the metal tabs surrounding the metal bracket mentioned in the previous step.
    • Remove the metal bracket using a small pick or a Phillips #00 screwdriver.
    • Close the phone.
  6. Samsung SGH-A237 Camera Replacement: passo 6, immagine 1 di 1
    • Find the camera on the upper part of the phone. It will be displayed as a small black circle.
    • Follow the copper ribbon connected to the camera downward to the black connection port.
  7. Samsung SGH-A237 Camera Replacement: passo 7, immagine 1 di 2 Samsung SGH-A237 Camera Replacement: passo 7, immagine 2 di 2
    • Failure to utilize the specified tool in the proper way may cause damage to the device.
    • Pry up the black connector using a pick. This should lock the black connector into an upward position, which will release the copper ribbon connected to the phone's camera.
  8. Samsung SGH-A237 Camera Replacement: passo 8, immagine 1 di 2 Samsung SGH-A237 Camera Replacement: passo 8, immagine 2 di 2
    • Gently grasp the copper ribbon attached to the camera using a pair of tweezers.
    • Gently pull copper ribbon towards the camera. This should pull the copper ribbon out completely.
  9. Samsung SGH-A237 Camera Replacement: passo 9, immagine 1 di 1
    • Remove the camera.
Conclusione
Jonathon
Membro da: 10/15/14
10 Reputazione
1 Guida realizzata
Ohio State, Team 1-4, Mccook Fall 2014 Membro di Ohio State, Team 1-4, Mccook Fall 2014
OSU-MCCOOK-F14S1G4
3 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 16
Tutti i Tempi: 349
