Introduzione
This repair guide shows how to replace the back cover on the Samsung SGH-237 cellphone.
Parti
Nessuna parte richiesta.
Put the phone face down so that the battery cover is showing. Put the phone face down so that the battery cover is showing.
  • Put the phone face down so that the battery cover is showing.
Aggiungi Commento
Use your thumb to push the battery cover off. Lift the battery off the device.
  • Use your thumb to push the battery cover off.
  • Lift the battery off the device.
Aggiungi Commento
Remove the five screws with a size 00 screwdriver. There are 4 in the corners and one on the top as shown. Remove the five screws with a size 00 screwdriver. There are 4 in the corners and one on the top as shown.
  • Remove the five screws with a size 00 screwdriver. There are 4 in the corners and one on the top as shown.
Aggiungi Commento
Carefully remove the back cover by using the iPod Opening Tool in the slots on the bottom of the device. Note: some force must be applied to remove back cover. Note: some force must be applied to remove back cover.
  • Carefully remove the back cover by using the iPod Opening Tool in the slots on the bottom of the device.
  • Note: some force must be applied to remove back cover.
Aggiungi Commento
Conclusione
Cal Poly, Team 29-81, Johann Spring 2010 Membro di Cal Poly, Team 29-81, Johann Spring 2010
CPSU-JOHANN-S10S29G81
4 Membri
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,321
