Introduzione
Use this guide to replace your Samsung SGH A707 phone's keypad.
Press on the markings on the cover and pull it down to reveal the battery.
  • Press on the markings on the cover and pull it down to reveal the battery.
Aggiungi Commento
Use your fingers to pull the battery out of its position. You may also flip the phone and the battery will fall out.
  • Use your fingers to pull the battery out of its position. You may also flip the phone and the battery will fall out.
Aggiungi Commento
Here is the phone without the battery.
  • Here is the phone without the battery.
Aggiungi Commento
Unscrew the six screws on the back of the phone using the Phillips #0 screw driver. Unscrew the six screws on the back of the phone using the Phillips #0 screw driver.
  • Unscrew the six screws on the back of the phone using the Phillips #0 screw driver.
Aggiungi Commento
Use the prying tool the pry off the phone's plastic frame.
  • Use the prying tool the pry off the phone's plastic frame.
Aggiungi Commento
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Use the prying tool to disconnect the rectangular connector. Use the prying tool to disconnect the rectangular connector. Use the prying tool to disconnect the rectangular connector.
  • Use the prying tool to disconnect the rectangular connector.
Aggiungi Commento
Use the prying tool to disconnect the small connector.
  • Use the prying tool to disconnect the small connector.
Aggiungi Commento
Gently pull off the circuit board.
  • Gently pull off the circuit board.
Aggiungi Commento
Here is the phone without the logic board.
  • Here is the phone without the logic board.
Aggiungi Commento
Hold the phone and gently separate the circuit board that holds the dome switches and the front face of the phone, revealing the rubber keyboard.
  • Hold the phone and gently separate the circuit board that holds the dome switches and the front face of the phone, revealing the rubber keyboard.
Aggiungi Commento
Here is the phone without the dome switch circuit board.
  • Here is the phone without the dome switch circuit board.
Aggiungi Commento
Here is the phone and the rubber keyboard. Here is the phone and the rubber keyboard.
  • Here is the phone and the rubber keyboard.
Aggiungi Commento
Here is the rubber keyboard and the dome switch circuit board. A quick inspection of these elements can reveal keypad malfunctions. Look for dirt or debris that do not belong there.
  • Here is the rubber keyboard and the dome switch circuit board. A quick inspection of these elements can reveal keypad malfunctions. Look for dirt or debris that do not belong there.
Aggiungi Commento
Conclusione
yfm
Membro da: 06/11/2012
10 Reputazione
14 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 442
