Salta al contenuto principale
Samsung SCH-U340 Lower Casing Replacement
Cosa ti serve
  1. Samsung SCH-U340 Lower Casing Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the cell phone so that the back side is facing you.
    • Press the upper indent and slide the back cover down.
  2. Samsung SCH-U340 Lower Casing Replacement: passo 2, immagine 1 di 1
    • Pull the battery up from indent at the bottom and slide it out.
  3. Samsung SCH-U340 Lower Casing Replacement: passo 3, immagine 1 di 1
    • Set the battery aside.
  4. Samsung SCH-U340 Lower Casing Replacement, Lower Casing: passo 4, immagine 1 di 1
    • The lower casing is held on by four screws in the corner of the battery enclosure. Remove these screws.
  5. Samsung SCH-U340 Lower Casing Replacement: passo 5, immagine 1 di 2 Samsung SCH-U340 Lower Casing Replacement: passo 5, immagine 2 di 2
    • Use a spudger to pry the back assembly off of the device.
Conclusione
Cal Poly, Team 3-21, Maness Winter 2010 Membro di Cal Poly, Team 3-21, Maness Winter 2010
CPSU-MANESS-W10S3G21
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 3,617
