Introduzione
Use this guide to remove the logic board assembly from the casing.
Parti
Nessuna parte richiesta.
Turn the cell phone so that the back side is facing you. Press the upper indent and slide the back cover down.
  • Turn the cell phone so that the back side is facing you. Press the upper indent and slide the back cover down.
Aggiungi Commento
Pull battery up from indent at the bottom and slide it out.
  • Pull battery up from indent at the bottom and slide it out.
Aggiungi Commento
Set the battery aside.
  • Set the battery aside.
Aggiungi Commento
The outer casing consists of two separate parts on the upper and lower halves of the device. The upper outer casing is held on through a combination of screws and tabs. First remove the plastic plugs covering the screws with a spudger.
  • The outer casing consists of two separate parts on the upper and lower halves of the device. The upper outer casing is held on through a combination of screws and tabs. First remove the plastic plugs covering the screws with a spudger.
Aggiungi Commento
Underneath the plugs are two small screws that can be removed with a small Phillips screwdriver. They will need to be pried out after unscrewing them due to their size. Take care not to lose the screws as they are small and have a tendency to roll.
  • Underneath the plugs are two small screws that can be removed with a small Phillips screwdriver. They will need to be pried out after unscrewing them due to their size. Take care not to lose the screws as they are small and have a tendency to roll.
Aggiungi Commento
The outer cover is now secured with seven tabs: one large tab (marked in red) and seven smaller tabs (marked in orange).
  • The outer cover is now secured with seven tabs: one large tab (marked in red) and seven smaller tabs (marked in orange).
    • To begin removing the outer cover start by prying the large tab up with a flat object.
Aggiungi Commento
Continue to pry each tab up, taking care not to break the tabs.
  • Continue to pry each tab up, taking care not to break the tabs.
  • If disaster strikes and a tab is broken, the outer casing can still be put back on assuming the majority of the tabs are still intact.
Aggiungi Commento
After the last tab is removed, tug gently on the outer casing to remove it. Don't pull too hard, or you may damage the wires connected to the speaker.
  • After the last tab is removed, tug gently on the outer casing to remove it. Don't pull too hard, or you may damage the wires connected to the speaker.
Aggiungi Commento
The lower casing is held on by four screws in the corner of the battery enclosure. Remove these screws.
  • The lower casing is held on by four screws in the corner of the battery enclosure. Remove these screws.
Aggiungi Commento
Use a spudger to pry the back assembly off of the device. Use a spudger to pry the back assembly off of the device.
  • Use a spudger to pry the back assembly off of the device.
Aggiungi Commento
Use spudger to pry logic board from the casing.
  • Use spudger to pry logic board from the casing.
Aggiungi Commento
Rotate the logic board assembly out of the casing, being careful not to break VGA cable.
  • Rotate the logic board assembly out of the casing, being careful not to break VGA cable.
Aggiungi Commento
Lift the number pad straight up from the casing.
  • Lift the number pad straight up from the casing.
Aggiungi Commento
Set the number pad to the side.
  • Set the number pad to the side.
Aggiungi Commento
Linea Traguardo
Cal Poly, Team 3-21, Maness Winter 2010 Membro di Cal Poly, Team 3-21, Maness Winter 2010
CPSU-MANESS-W10S3G21
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 3,273
