Introduzione
A step by step guide to removing and replacing the Samsung SCH U340's internal antennae.
Parti
Nessuna parte richiesta.
Turn the cell phone so that the back side is facing you. Press the upper indent and slide the back cover down.
  • Turn the cell phone so that the back side is facing you. Press the upper indent and slide the back cover down.
Aggiungi Commento
Pull battery up from indent at the bottom and slide it out.
  • Pull battery up from indent at the bottom and slide it out.
Aggiungi Commento
Set the battery aside.
  • Set the battery aside.
Aggiungi Commento
The lower casing is held on by four screws in the corner of the battery enclosure. Remove these screws.
  • The lower casing is held on by four screws in the corner of the battery enclosure. Remove these screws.
Aggiungi Commento
Use a spudger to pry the back assembly off of the device. Use a spudger to pry the back assembly off of the device.
  • Use a spudger to pry the back assembly off of the device.
Aggiungi Commento
On the bottom casing, there should be a single metal screw holding the antennae in. Remove this screw.
  • On the bottom casing, there should be a single metal screw holding the antennae in. Remove this screw.
Aggiungi Commento
Pry the antennae off by inserting a flat object such as a spudgel into the slot marked in yellow and pushing upwards. Pry the antennae off by inserting a flat object such as a spudgel into the slot marked in yellow and pushing upwards.
  • Pry the antennae off by inserting a flat object such as a spudgel into the slot marked in yellow and pushing upwards.
Aggiungi Commento
Conclusione
David Gomez
Membro da: 21/01/2010
1 Reputazione
2 Guide realizzate
Cal Poly, Team 3-21, Maness Winter 2010 Membro di Cal Poly, Team 3-21, Maness Winter 2010
CPSU-MANESS-W10S3G21
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 3,075
