Introduzione
This guide will teach you how remove your Samsung's SCH-A950's Volume and Camera Buttons.
Slide the the battery release tab upwards while simultaneously lifting the back cover straight up. Slide the the battery release tab upwards while simultaneously lifting the back cover straight up.
  • Slide the the battery release tab upwards while simultaneously lifting the back cover straight up.
Aggiungi Commento
Remove the four Phillips #00 screws underneath the battery.
  • Remove the four Phillips #00 screws underneath the battery.
Aggiungi Commento
Pull open the earphone tab and the Trans Flash tab using your fingers. Pull open the earphone tab and the Trans Flash tab using your fingers.
  • Pull open the earphone tab and the Trans Flash tab using your fingers.
Aggiungi Commento
Using a plastic opening tool, pry off the phone casing near the speakers as shown. Tabs located on the inside of the phone may make this difficult and some force may be required.
  • Using a plastic opening tool, pry off the phone casing near the speakers as shown. Tabs located on the inside of the phone may make this difficult and some force may be required.
  • Slide the casing slightly forward towards the top of the phone to remove.
Aggiungi Commento
Using tweezers or your fingers, lift off buttons from logic board. The buttons can be replaced if needed. The buttons can be replaced if needed.
  • Using tweezers or your fingers, lift off buttons from logic board.
  • The buttons can be replaced if needed.
Aggiungi Commento
Conclusione
Sean Kennedy
Membro da: 13/01/2010
49 Reputazione
2 Guide realizzate
Cal Poly, Team 11-5, Forte Winter 2010 Membro di Cal Poly, Team 11-5, Forte Winter 2010
CPSU-FORTE-W10S11G5
5 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,758
