Salta al contenuto principale
Samsung SCH-A670 Keypad Replacement
Cosa ti serve
  1. Samsung SCH-A670 Keypad Replacement, Battery Cover: passo 1, immagine 1 di 1
    • Slide the latch on the back of the phone up.
  2. Samsung SCH-A670 Keypad Replacement, Battery: passo 2, immagine 1 di 1
    • Remove the battery.
  3. Samsung SCH-A670 Keypad Replacement, Logic Board: passo 3, immagine 1 di 1
    • After removing the battery, remove the four small Phillips-head screws with a #0 Phillips screwdriver.
  4. Samsung SCH-A670 Keypad Replacement: passo 4, immagine 1 di 1
    • Using a thumbtack, pry the small plastic cover from the case near the base of the antenna.
  5. Samsung SCH-A670 Keypad Replacement: passo 5, immagine 1 di 1
    • With a #0 Phillips screwdriver remove the screw which you just uncovered.
  6. Samsung SCH-A670 Keypad Replacement: passo 6, immagine 1 di 2 Samsung SCH-A670 Keypad Replacement: passo 6, immagine 2 di 2
    • Using the spudger, carefully pry the case apart starting near the charging port. Ease the case open.
    • Then disconnect the small power connector near the top of the phone.
  7. Samsung SCH-A670 Keypad Replacement: passo 7, immagine 1 di 1
    • Gently pry up the ribbon-type connector with the spudger.
  8. Samsung SCH-A670 Keypad Replacement: passo 8, immagine 1 di 1
    • Carefully pry the logic board from the case with the spudger.
  9. Samsung SCH-A670 Keypad Replacement, Keypad: passo 9, immagine 1 di 1
    • Once the logic board has been removed, peel the keypad up.
Conclusione
Nathan Brink
Membro da: 04/11/10
19 Reputazione
7 Guide realizzate
Cal Poly, Team 34-59, Forte Spring 2010 Membro di Cal Poly, Team 34-59, Forte Spring 2010
CPSU-FORTE-S10S34G59
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,555
