Salta al contenuto principale
Samsung SCH-8500 Volume Button Replacement
Cosa ti serve
  1. Samsung SCH-8500 Volume Button Replacement, Battery: passo 1, immagine 1 di 3 Samsung SCH-8500 Volume Button Replacement, Battery: passo 1, immagine 2 di 3 Samsung SCH-8500 Volume Button Replacement, Battery: passo 1, immagine 3 di 3
    • To separate the battery from the phone, use your thumb to push in the button as shown.
    • Keep the unlock button pressed as you slide the battery away from the button.
    • Pull the battery away from the phone.
  2. Samsung SCH-8500 Volume Button Replacement, Back Case: passo 2, immagine 1 di 3 Samsung SCH-8500 Volume Button Replacement, Back Case: passo 2, immagine 2 di 3 Samsung SCH-8500 Volume Button Replacement, Back Case: passo 2, immagine 3 di 3
    • Use a T6 Torx screwdriver to remove the highlighted screws.
    • These are the four screws, about 10 mm long, that need to be removed. Be careful with the screws as they are small and easy to misplace.
    • Carefully pry apart the two pieces, laying the back case to the side.
  3. Samsung SCH-8500 Volume Button Replacement, Volume Button: passo 3, immagine 1 di 3 Samsung SCH-8500 Volume Button Replacement, Volume Button: passo 3, immagine 2 di 3 Samsung SCH-8500 Volume Button Replacement, Volume Button: passo 3, immagine 3 di 3
    • With the back case fully removed and out of the way, use your fingers to remove the volume button.
    • Use caution in removal to prevent damaging any circuitry in the phone.
Conclusione
Clemson, Team 14-6, Benson Fall 2012 Membro di Clemson, Team 14-6, Benson Fall 2012
CLEM-BENSON-F12S14G6
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 14
Tutti i Tempi: 204
