Introduzione
This guide will teach you how to get to and replace the plastic keypad from the phone.
Parti
Nessuna parte richiesta.
To separate the battery from the phone, use your thumb to push in the button as shown. Keep the unlock button pressed as you slide the battery away from the button. Pull the battery away from the phone.
  • To separate the battery from the phone, use your thumb to push in the button as shown.
  • Keep the unlock button pressed as you slide the battery away from the button.
  • Pull the battery away from the phone.
Aggiungi Commento
Use a T6 Torx screwdriver to remove the highlighted screws. These are the four screws, about 10 mm long, that need to be removed. Be careful with the screws as they are small and easy to misplace. Carefully pry apart the two pieces, laying the back case to the side.
  • Use a T6 Torx screwdriver to remove the highlighted screws.
  • These are the four screws, about 10 mm long, that need to be removed. Be careful with the screws as they are small and easy to misplace.
  • Carefully pry apart the two pieces, laying the back case to the side.
Aggiungi Commento
With the back case fully removed and out of the way, use your fingers to remove the volume button. Use caution in removal to prevent damaging any circuitry in the phone. Use caution in removal to prevent damaging any circuitry in the phone.
  • With the back case fully removed and out of the way, use your fingers to remove the volume button.
  • Use caution in removal to prevent damaging any circuitry in the phone.
Aggiungi Commento
The circuit board is hardwired to other components in the phone and cannot be completely removed. Take extreme precaution when performing this step as to not damage the circuitry or the wiring. Lift the circuit board up slightly. With the circuit board lifted, remove the plastic keypad and place to the side.
  • The circuit board is hardwired to other components in the phone and cannot be completely removed. Take extreme precaution when performing this step as to not damage the circuitry or the wiring.
  • Lift the circuit board up slightly.
  • With the circuit board lifted, remove the plastic keypad and place to the side.
Aggiungi Commento
Conclusione
Will Gunter
Membro da: 23/10/2012
1 Reputazione
8 Guide realizzate
Clemson, Team 14-6, Benson Fall 2012 Membro di Clemson, Team 14-6, Benson Fall 2012
CLEM-BENSON-F12S14G6
3 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 169
