Introduzione
This guide will provide a step-by-step procedure for replacing the antenna and speaker in your Samsung Rogue.
Parti
Nessuna parte richiesta.
Before disassembling your Samsung Rogue, make sure it is powered off. With your thumbs, push down on the back cover of your phone and slide it away from the camera.
  • Before disassembling your Samsung Rogue, make sure it is powered off.
  • With your thumbs, push down on the back cover of your phone and slide it away from the camera.
Aggiungi Commento
You can now remove the battery by prying it up with your finger. You can now remove the battery by prying it up with your finger.
  • You can now remove the battery by prying it up with your finger.
Aggiungi Commento
Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
  • Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
Aggiungi Commento
Remove the five 3.4mm Philips screws securing the backing of the phone.
  • Remove the five 3.4mm Philips screws securing the backing of the phone.
Aggiungi Commento
Use a plastic opening tool to carefully pry off the back cover. Make sure you are prying along the edge and not between the two halves of the phone that slide away from each other. Be careful to not drop the volume changing piece, for it can easily slip out.
  • Use a plastic opening tool to carefully pry off the back cover.
  • Make sure you are prying along the edge and not between the two halves of the phone that slide away from each other.
  • Be careful to not drop the volume changing piece, for it can easily slip out.
Aggiungi Commento
Remove the two 3.45 mm Philips screws below the white sticker.
  • Remove the two 3.45 mm Philips screws below the white sticker.
Aggiungi Commento
Carefully lift the motherboard up from the bottom edge. The film of wires is still attached to the motherboard, so do not completely remove the motherboard just yet or you may damage it.
  • Carefully lift the motherboard up from the bottom edge.
  • The film of wires is still attached to the motherboard, so do not completely remove the motherboard just yet or you may damage it.
Aggiungi Commento
Use a plastic opening tool to disconnect the film from the motherboard. Use a plastic opening tool to disconnect the film from the motherboard.
  • Use a plastic opening tool to disconnect the film from the motherboard.
Aggiungi Commento
On the underside of the motherboard, remove the single 3.3mm Philips screw.
  • On the underside of the motherboard, remove the single 3.3mm Philips screw.
Aggiungi Commento
The speaker and the antenna are both connected on the same black piece. Use a plastic opening tool to pop off the edges of the speaker/antenna piece from the motherboard. Turn over the motherboard and carefully lift the speaker/antenna piece straight up.
  • The speaker and the antenna are both connected on the same black piece.
  • Use a plastic opening tool to pop off the edges of the speaker/antenna piece from the motherboard.
  • Turn over the motherboard and carefully lift the speaker/antenna piece straight up.
  • The camera is held in the middle of the speaker/antenna piece. Make sure to lift directly up when lifting the speaker/antenna piece, otherwise you can risk damaging the camera.
Aggiungi Commento
Conclusione
Cal Poly, Team 7-32, Maness Spring 2012 Membro di Cal Poly, Team 7-32, Maness Spring 2012
CPSU-MANESS-S12S7G32
4 Membri
16 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 279
