Introduzione
This guide will provide a step-by-step procedure for replacing the camera in your Samsung Rogue.
Cosa ti serve
With your thumbs, push down on the back cover of your phone and slide it away from the camera.
Use a plastic opening tool to carefully pry the back cover surrounding the camera up from the phone.
On the underside of the motherboard, remove the single 3.3mm Philips screw.
With two fingers carefully detach the camera from the motherboard by lifting straight up.
