Introduzione
In order to gain access to the rear case, you must remove the back cover and battery. Be sure to have the necessary tools for removing the screws holding the rear case in place.
Parti
Nessuna parte richiesta.
Turn phone over in the palm of your hand, with the screen facing down.
  • Turn phone over in the palm of your hand, with the screen facing down.
  • While grasping the bottom part of the phone with one hand, use your thumb to push the release button at the end of the phone.
  • This will release the back plate latch; then lift the back plate up and out toward the other end of the phone.
  • You should now be able to lift the plate completely off the phone.
Aggiungi Commento
Hold the phone steady with one hand.
  • Hold the phone steady with one hand.
  • In the other hand use a philips screwdriver to loosen and remove all 3 screws.
Aggiungi Commento
Gently lift off the rear case from the front case.
  • Gently lift off the rear case from the front case.
Aggiungi Commento
Conclusione
Denise Cooper
Membro da: 18/10/2011
31 Reputazione
6 Guide realizzate
James Madison, Team 1-6, Allen Fall 2011 Membro di James Madison, Team 1-6, Allen Fall 2011
JMU-ALLEN-F11S1G6
4 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,039
