Salta al contenuto principale
Samsung Rant Keypad Replacement
Cosa ti serve
  1. Samsung Rant Keypad Replacement, Back Cover: passo 1, immagine 1 di 1
    • Turn the phone over in the palm of your hand, with the screen facing down.
    • While grasping the bottom part of the phone with one hand, use your thumb to push the release button at the end of the phone.
    • This will release the back plate latch; then lift the back plate up and out toward the other end of the phone.
    • You should now be able to lift the plate completely off of the phone.
  2. Samsung Rant Keypad Replacement, Battery: passo 2, immagine 1 di 1
    • Carefully remove the battery from the phone.
  3. Samsung Rant Keypad Replacement, Rear Case: passo 3, immagine 1 di 1
    • Use a Phillips #00 screwdriver to loosen and remove all 3 screws.
  4. Samsung Rant Keypad Replacement: passo 4, immagine 1 di 1
    • Gently separate the rear case from the front case.
  5. Samsung Rant Keypad Replacement, Keypad: passo 5, immagine 1 di 2 Samsung Rant Keypad Replacement, Keypad: passo 5, immagine 2 di 2
    • Using a pair of tweezers, grip the keypad gently.
    • Lift the keypad out of the phone and replace it (if necessary).
Conclusione
James Madison, Team 1-6, Allen Fall 2011 Membro di James Madison, Team 1-6, Allen Fall 2011
JMU-ALLEN-F11S1G6
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,439
