Introduzione
To remove the battery in the Samsung Rant, you must first remove the back cover. Then the battery will be accessible for removal.
Strumenti
Nessun attrezzo richiesto.
Parti
Nessuna parte richiesta.
Turn phone over in the palm of your hand, with the screen facing down.
  • Turn phone over in the palm of your hand, with the screen facing down.
  • While grasping the bottom part of the phone with one hand, use your thumb to push the release button at the end of the phone.
  • This will release the back plate latch; then lift the back plate up and out toward the other end of the phone.
  • You should now be able to lift the plate completely off the phone.
Aggiungi Commento
Place your thumb at the noched area at the bottom portion of the phone.
  • Place your thumb at the noched area at the bottom portion of the phone.
  • Gently lift up and pull the battery out in the opposite direction.
Aggiungi Commento
Take battery out of phone.
  • Take battery out of phone.
Aggiungi Commento
Conclusione
*New Battery information: Standard Lithium Ion (Li-Ion); Talk time: 5.6 hours max. (336 minutes)
Todd
Membro da: 18/10/2011
1 Reputazione
2 Guide realizzate
James Madison, Team 1-6, Allen Fall 2011 Membro di James Madison, Team 1-6, Allen Fall 2011
JMU-ALLEN-F11S1G6
4 Membri
11 Guide realizzate
*New batteries need to be charged before use.
*You should charge your battery in an area that is free of moisture, extreme cold or extreme heat.
*Refer to the repair manual (Samsung Rant Device page above) for information on purchasing a battery and battery life.
Denise Cooper - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,236
