Salta al contenuto principale
Samsung RF4287HABP Ice Maker Repair
Cosa ti serve
  1. Samsung RF4287HABP Ice Maker Repair, Samsung RF4287HABP Ice Maker Repair: passo 1, immagine 1 di 1
    • Push the “Energy Saver” button and “Fridge” button for about 8 seconds.
  2. Samsung RF4287HABP Ice Maker Repair: passo 2, immagine 1 di 1
    • After you hear a beep, continue to press the “Energy Saver” button until “Fd” appears.
    • The refrigerator will continue to beep for approximately 20 minutes until the ice maker has defrosted.
    • Unplug the refrigerator before beginning step 3.
  3. Samsung RF4287HABP Ice Maker Repair: passo 3, immagine 1 di 3 Samsung RF4287HABP Ice Maker Repair: passo 3, immagine 2 di 3 Samsung RF4287HABP Ice Maker Repair: passo 3, immagine 3 di 3
    • Take the ice maker tray out of the icebox and place it in the sink to melt the remaining ice off.
  4. Samsung RF4287HABP Ice Maker Repair: passo 4, immagine 1 di 1
    • Attempt to scrape any ice out of the icebox and defrost the remaining ice with a hairdryer or heat gun.
    • Use caution when applying heat. Excessive heat may cause the plastic to warp or melt, which could cause fit issues during installation.
  5. Samsung RF4287HABP Ice Maker Repair: passo 5, immagine 1 di 2 Samsung RF4287HABP Ice Maker Repair: passo 5, immagine 2 di 2
    • Unscrew the 0.05 mm screw on the left side panel inside the icebox with a Phillips #0 screwdriver.
  6. Samsung RF4287HABP Ice Maker Repair: passo 6, immagine 1 di 2 Samsung RF4287HABP Ice Maker Repair: passo 6, immagine 2 di 2
    • Carefully detach the plug connected to the thick white tube located to the left in the back of the icebox.
  7. Samsung RF4287HABP Ice Maker Repair: passo 7, immagine 1 di 2 Samsung RF4287HABP Ice Maker Repair: passo 7, immagine 2 di 2
    • Press the lever down and slide the ice maker forward at the very top of the icebox.
    • If the lever is stuck, it could be from the remaining ice in your ice maker.
  8. Samsung RF4287HABP Ice Maker Repair: passo 8, immagine 1 di 1
    • Take out the ice tray and place it in the sink. Use a hairdryer to defrost the ice tray completely.
    • Reinsert and reconnect all the parts of the icemaker.
  9. Samsung RF4287HABP Ice Maker Repair: passo 9, immagine 1 di 1
    • Plug the refrigerator back into the electrical outlet.
    • Press and hold the restart button located on the top of the ice maker beside the lever.
  10. Samsung RF4287HABP Ice Maker Repair: passo 10, immagine 1 di 1
    • Unplug and plug the refrigerator if you do not hear a sound from the ice maker. Press and hold the restart button again until you hear water draining into the ice maker.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 96
Tutti i Tempi: 4,220
