Salta al contenuto principale
Samsung Portable Dualband Tri-Mode External Speaker Replacement
Cosa ti serve
  1. Samsung Portable Dualband Tri-Mode External Speaker Replacement, Battery: passo 1, immagine 1 di 2 Samsung Portable Dualband Tri-Mode External Speaker Replacement, Battery: passo 1, immagine 2 di 2
    • Slide the battery out from the battery compartment on the back of the phone.
  2. Samsung Portable Dualband Tri-Mode External Speaker Replacement, Antenna: passo 2, immagine 1 di 2 Samsung Portable Dualband Tri-Mode External Speaker Replacement, Antenna: passo 2, immagine 2 di 2
    • Unscrew the antenna top.
  3. Samsung Portable Dualband Tri-Mode External Speaker Replacement: passo 3, immagine 1 di 3 Samsung Portable Dualband Tri-Mode External Speaker Replacement: passo 3, immagine 2 di 3 Samsung Portable Dualband Tri-Mode External Speaker Replacement: passo 3, immagine 3 di 3
    • Clasp the antenna with tweezers and push toward the top.
    • Remove the antenna.
  4. Samsung Portable Dualband Tri-Mode External Speaker Replacement, Backplate: passo 4, immagine 1 di 3 Samsung Portable Dualband Tri-Mode External Speaker Replacement, Backplate: passo 4, immagine 2 di 3 Samsung Portable Dualband Tri-Mode External Speaker Replacement, Backplate: passo 4, immagine 3 di 3
    • Remove the four screws (3 mm) from the battery compartment.
    • Press the release buttons located on the side of the phone while gently prying the back plate off.
  5. Samsung Portable Dualband Tri-Mode External Speaker Replacement, Motherboard: passo 5, immagine 1 di 3 Samsung Portable Dualband Tri-Mode External Speaker Replacement, Motherboard: passo 5, immagine 2 di 3 Samsung Portable Dualband Tri-Mode External Speaker Replacement, Motherboard: passo 5, immagine 3 di 3
    • Press the release tabs on the sides of the back casing.
    • Gently pry the motherboard loose and remove it.
  6. Samsung Portable Dualband Tri-Mode External Speaker Replacement, External Speaker: passo 6, immagine 1 di 3 Samsung Portable Dualband Tri-Mode External Speaker Replacement, External Speaker: passo 6, immagine 2 di 3 Samsung Portable Dualband Tri-Mode External Speaker Replacement, External Speaker: passo 6, immagine 3 di 3
    • Locate the back plate of the phone. Turn the back plate over to view the inside.
    • Remove the 2 mm screw from the top of the inner back casing of the phone.
  7. Samsung Portable Dualband Tri-Mode External Speaker Replacement: passo 7, immagine 1 di 2 Samsung Portable Dualband Tri-Mode External Speaker Replacement: passo 7, immagine 2 di 2
    • With the flat head screwdriver, remove the external speaker unit.
  8. Samsung Portable Dualband Tri-Mode External Speaker Replacement: passo 8, immagine 1 di 2 Samsung Portable Dualband Tri-Mode External Speaker Replacement: passo 8, immagine 2 di 2
    • Take the external speaker unit and turn it over.
    • Remove the black rubber casing.
  9. Samsung Portable Dualband Tri-Mode External Speaker Replacement: passo 9, immagine 1 di 2 Samsung Portable Dualband Tri-Mode External Speaker Replacement: passo 9, immagine 2 di 2
    • Use tweezers to remove the external speaker from the small unit.
Conclusione
Barbara
Membro da: 03/26/14
413 Reputazione
4 Guide realizzate
Clemson, Team 6-2, Benson Spring 2014 Membro di Clemson, Team 6-2, Benson Spring 2014
CLEM-BENSON-S14S6G2
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 245
