Introduzione
Given to us to find out whats happened to the keyboard (Sticky keys), thought it might be helpful to post a guide
Quite a simple stage.  There are a total of 19 screws to be removed from the bottom of the casing. Three for HDD
  • Quite a simple stage. There are a total of 19 screws to be removed from the bottom of the casing.
    • Three for HDD
    • One for Ram/HDD Cover
    • One for ODD
    • one hidden under a rubber foot at the front of the laptop.
    • Three under the Battery
  • Make sure you remove the fake SD Card at the front, because this can stall you.
Aggiungi Commento
Once the cover is off, there are three screws holding the main PCB down. Screws for the HDD Battery.  DC 11.1V 57W
  • Once the cover is off, there are three screws holding the main PCB down.
  • Screws for the HDD
  • Battery. DC 11.1V 57W
Aggiungi Commento
This shows the main PCB USB 3.0 Ports
  • This shows the main PCB
  • USB 3.0 Ports
Aggiungi Commento
locations of the main PCB / WIFI card screws. locations of the main PCB / WIFI card screws. locations of the main PCB / WIFI card screws.
  • locations of the main PCB / WIFI card screws.
Aggiungi Commento
removing the Main PCB means detaching the cable marked M, W the big fat black cable at the top and the white connector at the right usb side. removing the Main PCB means detaching the cable marked M, W the big fat black cable at the top and the white connector at the right usb side. removing the Main PCB means detaching the cable marked M, W the big fat black cable at the top and the white connector at the right usb side.
  • removing the Main PCB means detaching the cable marked M, W the big fat black cable at the top and the white connector at the right usb side.
Aggiungi Commento
Here's the underside of the main PCB, all cables detached. With the PCB removed this is all you have left.
  • Here's the underside of the main PCB, all cables detached.
  • With the PCB removed this is all you have left.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Robbie Steele
Membro da: 22/04/2010
110 Reputazione
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 23
Tutti i Tempi: 2,008
