Introduzione
This guide will show you how to replace a faulty speaker.
Parti
Nessuna parte richiesta.
Slide your fingernail into the slit at the bottom of the phone to remove the back cover.
  • Slide your fingernail into the slit at the bottom of the phone to remove the back cover.
Aggiungi Commento
Place your finger in either of the bottom corner of the battery slot and lift to remove the battery.
  • Place your finger in either of the bottom corner of the battery slot and lift to remove the battery.
Aggiungi Commento
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Remove six 5 mm Phillips #0 screws from the back of the phone.
  • Remove six 5 mm Phillips #0 screws from the back of the phone.
Aggiungi Commento
Insert a plastic opening tool into the seam between the back case and the rest of the phone.
  • Insert a plastic opening tool into the seam between the back case and the rest of the phone.
  • Working along the seam, pry the back from the phone.
Aggiungi Commento
Find the back casing of the phone. Slide the plastic opening tool under the bottom of the speaker to pop it out. Find the back casing of the phone. Slide the plastic opening tool under the bottom of the speaker to pop it out.
  • Find the back casing of the phone. Slide the plastic opening tool under the bottom of the speaker to pop it out.
Aggiungi Commento
Conclusione
Morgan Yost
Membro da: 08/04/2013
46 Reputazione
12 Guide realizzate
Cal Poly, Team 17-1, Regan Spring 2013 Membro di Cal Poly, Team 17-1, Regan Spring 2013
CPSU-REGAN-S13S17G1
4 Membri
18 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 137
