Introduzione
A guide to help replace the spring inside of the setting knob on top of the camera.
Remove the six external screws from the camera using a Phillips #0 screwdriver. After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera. Be careful, make sure you don't lose the screws.
  • Remove the six external screws from the camera using a Phillips #0 screwdriver.
  • After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
  • Be careful, make sure you don't lose the screws.
Aggiungi Commento
Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery. Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
  • Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
Aggiungi Commento
Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera. Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera. Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
  • Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
Aggiungi Commento
Carefully squeeze the top right corner of the camera and pry off the external cover.
  • Carefully squeeze the top right corner of the camera and pry off the external cover.
  • If you hear a "cracking" sound. This is normal.
  • Continue to pull the external cover and it will come off cleanly.
  • Be cautious of the flash capacitor. It carries an electrical charge, that may give you an unpleasant shock.
Aggiungi Commento
Carefully pull off the back cover, parts behind the back of the case might fall out.
  • Carefully pull off the back cover, parts behind the back of the case might fall out.
Aggiungi Commento
Remove the screws holding the circuit board.
  • Remove the screws holding the circuit board.
  • After you remove the screws, carefully remove the circuit board.
Aggiungi Commento
Remove the front cover, it comes off easily. Buttons might fall out when you remove the front cover.
  • Remove the front cover, it comes off easily.
  • Buttons might fall out when you remove the front cover.
Aggiungi Commento
Face camera towards you.
  • Face camera towards you.
  • Remove the two screws from circuit board on the left side of the lens.
Aggiungi Commento
Carefully hold up the circuit board, while it's still connected to the camera.
  • Carefully hold up the circuit board, while it's still connected to the camera.
  • Remove all five screws that's on top of the camera.
Aggiungi Commento
Carefully push up the top of the circuit board. Pull up flash circuit board from top of camera. Pull up flash circuit board from top of camera.
  • Carefully push up the top of the circuit board.
  • Pull up flash circuit board from top of camera.
Aggiungi Commento
Face the bottom of the Flash Circuit board towards you.
  • Face the bottom of the Flash Circuit board towards you.
  • Remove the one screw that's located on the left side of the lens.
Aggiungi Commento
Take the flash circuit board and turn it over.
  • Take the flash circuit board and turn it over.
  • Remove the plastic setting knob.
  • Make sure to keep copper spring inside of the slot.
Aggiungi Commento
Take out and replace the Setting Knob Spring with tweezers. Take out and replace the Setting Knob Spring with tweezers. Take out and replace the Setting Knob Spring with tweezers.
  • Take out and replace the Setting Knob Spring with tweezers.
Aggiungi Commento
Conclusione
andyhe
Membro da: 15/04/2010
72 Reputazione
1 Guida realizzata
Cal Poly, Team 6-17, Maness Spring 2010 Membro di Cal Poly, Team 6-17, Maness Spring 2010
CPSU-MANESS-S10S6G17
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,909
