Cosa ti serve
Press and hold down the button on the bottom side of the phone with your finger.
Remove the four screws from the back of the phone using a Phillips #00 screwdriver.
Use the iFixit opening tool to remove the yellow tab on the motherboard.
Open/swivel the phone so the back of the LCD panel is visible.
Use the iFixit opening tool to pry the keypad from the hinge on the back of the device.
Using your fingernail, remove the stickers covering the screws on the back of the LCD casing.
Remove six 3.5 mm screws from the back of the device using a Phillips #00 screwdriver.
Using tweezers, grip the red and blue wires that attach the audio earpiece to the outer casing and pull.
Altre 2 persone hanno completato questa guida.
