Introduzione
This guide shows how to take out the antenna so that a replacement can be installed.
Parti
Nessuna parte richiesta.
Apply pressure to the back cover and slide it forward towards the camera.
  • Apply pressure to the back cover and slide it forward towards the camera.
  • Lift the back cover off the phone.
Aggiungi Commento
Holding the phone firmly, use the notches to grip and lift up the battery.
  • Holding the phone firmly, use the notches to grip and lift up the battery.
Aggiungi Commento
Remove the four 4.45mm screws at the corners of the phone.
  • Remove the four 4.45mm screws at the corners of the phone.
Aggiungi Commento
Use the plastic opening tool to unhinge the locks around the edges of the phone. Do not worry about the inner components of the phone; they are not connected to this case.
  • Use the plastic opening tool to unhinge the locks around the edges of the phone.
  • Do not worry about the inner components of the phone; they are not connected to this case.
Aggiungi Commento
Lift the casing off of the phone.
  • Lift the casing off of the phone.
Aggiungi Commento
With the screws removed, locate the antenna.
  • With the screws removed, locate the antenna.
Aggiungi Commento
Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
  • Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
Aggiungi Commento
Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
  • Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
Aggiungi Commento
Gently lift up on the antenna and remove it from the back of the device.
  • Gently lift up on the antenna and remove it from the back of the device.
Aggiungi Commento
Conclusione
Jimmy Kuo
Membro da: 10/10/2011
14 Reputazione
4 Guide realizzate
Cal Poly, Team 3-13, Regan Fall 2011 Membro di Cal Poly, Team 3-13, Regan Fall 2011
CPSU-REGAN-F11S3G13
4 Membri
16 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 966
