Introduzione
How to remove & replace the phone's digitizer or front buttons
Cosa ti serve
Orient the phone with the screen facing down.
Using your thumb, slide the back panel away from the camera to expose the battery.
Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Make sure to unscrew in a counterclockwise direction.
To free the circuit board, remove the black wire that is holding it down.
Remove the two base screws along the edge of the silver piece, where you just removed the black end piece.
The screws are 2.7mm in length.
The bottom black end cap will snap out.
Remove the 3 screws holding down the flex cable.
The screws are 2.0 mm in length.
The screw that goes through the circle port on the flex cable is longer at 2.3mm long.
The keyboard slider frame will come off and the flex cable exposed, but not free.
Remove the single screw.
This screw is 2.25 mm in length.
Lift the black tab at the end of the ribbon.
Gently pull the speaker and ribbon free.
Lift the remaining two tabs and free their respective ribbon cables.
Gently pry the screen away from the housing.
If replacing the front buttons, remove the assembly at the bottom of the front panel
The digitizer is now free to be pulled out from the front housing.
Altre 3 persone hanno completato questa guida.
