Salta al contenuto principale
Samsung Impression Circuit Board Replacement
Cosa ti serve
  1. Samsung Impression Circuit Board Replacement, Battery: passo 1, immagine 1 di 1
    • Orient the phone with the screen facing down.
    • Using your thumb, slide the back panel away from the camera to expose the battery.
  2. Samsung Impression Circuit Board Replacement: passo 2, immagine 1 di 2 Samsung Impression Circuit Board Replacement: passo 2, immagine 2 di 2
    • Insert the tip of the spudger on the left side of the battery, opposite the direction of the white arrow.
    • Pry the battery free. It will pivot in the direction of the white arrow.
  3. Samsung Impression Circuit Board Replacement, Back Cover: passo 3, immagine 1 di 1
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Make sure to unscrew in a counterclockwise direction.
  4. Samsung Impression Circuit Board Replacement: passo 4, immagine 1 di 1
    • Remove the back cover by gently prying around the top and bottom edges with the spudger.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and will fall out, so put these in a safe place.
  5. Samsung Impression Circuit Board Replacement, Back Speaker: passo 5, immagine 1 di 1
    • Remove the back speaker by carefully prying it upwards with the spudger.
    • The speaker will still be attached to the circuit board by a wire and a small piece of clear plastic.
    • Disconnect the speaker by lifting the clear plastic piece at the end of the wire.
  6. Samsung Impression Circuit Board Replacement, Circuit Board: passo 6, immagine 1 di 1
    • To free the circuit board, remove the black wire that is holding it down.
    • You can remove the wire by gently prying up the gold terminator that is attached to the green circuit board. A gentle tug is all it should take.
  7. Samsung Impression Circuit Board Replacement: passo 7, immagine 1 di 2 Samsung Impression Circuit Board Replacement: passo 7, immagine 2 di 2
    • The circuit board will still be held on by a blue and black ribbon. Remove the entire circuit board by gently tugging the ribbon upwards.
Conclusione
To reassemble the device, carefully follow these instructions in reverse order. With a new circuit board installed, your phone should be functional again! For more guides on Samsung Impression maintenance, visit www.ifixit.com.
Ross McKelvie
Membro da: 04/18/11
196 Reputazione
4 Guide realizzate
Cal Poly, Team 8-10, Regan Spring 2011 Membro di Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Membri
22 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 3,803
