Introduzione
How to remove & replace the phone's back speaker.
Parti
Nessuna parte richiesta.
Orient the phone with the screen facing down.
  • Orient the phone with the screen facing down.
  • Using your thumb, slide the back panel away from the camera to expose the battery.
Aggiungi Commento
Grip the battery on its sides, opposite the direction of the white arrow. Pry the battery up. It will pivot at the end with the white arrow. The battery will now be free.
  • Grip the battery on its sides, opposite the direction of the white arrow.
  • Pry the battery up. It will pivot at the end with the white arrow. The battery will now be free.
Aggiungi Commento
Remove the 6 outer screws.
  • Remove the 6 outer screws.
    • The screws should be 3.5 mm in length.
  • Put the screws in a safe place as they are very small and easy to lose.
Aggiungi Commento
Snap off back the cover by gently prying around the top and bottom edges with a flat head screwdriver.
  • Snap off back the cover by gently prying around the top and bottom edges with a flat head screwdriver.
    • It may help to slide the touchscreen upwards when removing the back panel.
  • The side buttons will become loose and are prone to fall out, so put these in a safe place.
Aggiungi Commento
Remove the back speaker by carefully lifting it up.
  • Remove the back speaker by carefully lifting it up.
  • The speaker will still be attached to the circuit board by a wire and a small piece of clear plastic.
  • Disconnect the speaker by lifting the clear plastic piece at the end of the wire.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Ross McKelvie
Membro da: 18/04/2011
196 Reputazione
8 Guide realizzate
Cal Poly, Team 8-10, Regan Spring 2011 Membro di Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Membri
22 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,962
