Introduzione
Shows how to replace the lens through pictures and words. The lens is located on the motherboard and requires tweezers to unplug ribbons and the remove motherboard from the rear case.
To remove the wristband of the device, grab the middle loop and pull. Pull the band through as shown in the picture. To remove the wristband of the device, grab the middle loop and pull. Pull the band through as shown in the picture. To remove the wristband of the device, grab the middle loop and pull. Pull the band through as shown in the picture.
  • To remove the wristband of the device, grab the middle loop and pull. Pull the band through as shown in the picture.
Aggiungi Commento
Remove all four Hex screws with a Hex 1.5 mm screwdriver. Remove all four Hex screws with a Hex 1.5 mm screwdriver.
  • Remove all four Hex screws with a Hex 1.5 mm screwdriver.
Aggiungi Commento
To remove the HDMI screw, open the HDMI door on the side. Remove the screw using a Phillip size 00. To remove the HDMI screw, open the HDMI door on the side. Remove the screw using a Phillip size 00. To remove the HDMI screw, open the HDMI door on the side. Remove the screw using a Phillip size 00.
  • To remove the HDMI screw, open the HDMI door on the side. Remove the screw using a Phillip size 00.
Aggiungi Commento
As shown in the picture, use the plastic opening tool on both sides on the device. Pry apart both parts. Do not pry apart the device too hard. There is a wire that attaches the front case with the rear case. Do not pry apart the device too hard. There is a wire that attaches the front case with the rear case.
  • As shown in the picture, use the plastic opening tool on both sides on the device. Pry apart both parts.
  • Do not pry apart the device too hard. There is a wire that attaches the front case with the rear case.
Aggiungi Commento
Pull the wire ribbon out with a pair of tweezers. Pull the wire ribbon out with a pair of tweezers. Pull the wire ribbon out with a pair of tweezers.
  • Pull the wire ribbon out with a pair of tweezers.
Aggiungi Commento
Use tweezers to remove the tape. Use tweezers to remove the tape. Use tweezers to remove the tape.
  • Use tweezers to remove the tape.
Aggiungi Commento
Use tweezers to grab the wire ribbon, then pull the wire out of connection. Use tweezers to grab the wire ribbon, then pull the wire out of connection.
  • Use tweezers to grab the wire ribbon, then pull the wire out of connection.
Aggiungi Commento
There are 5 Phillips size 00 screws. Remove all 5 screws. Wire ribbon is attached to the motherboard.
  • There are 5 Phillips size 00 screws. Remove all 5 screws.
  • Wire ribbon is attached to the motherboard.
Aggiungi Commento
Pry the motherboard up using the  plastic opening tool.
  • Pry the motherboard up using the plastic opening tool.
  • Be careful there is a wire ribbon holding the motherboard.
Aggiungi Commento
Use tweezers to disconnect the wire as shown. This will loosen the motherboard from the rear case. Use tweezers to disconnect the wire as shown. This will loosen the motherboard from the rear case.
  • Use tweezers to disconnect the wire as shown. This will loosen the motherboard from the rear case.
Aggiungi Commento
Shows front of motherboard and rear of motherboard. Lens has 4 Phillips size 00 screws.
  • Shows front of motherboard and rear of motherboard.
  • Lens has 4 Phillips size 00 screws.
Aggiungi Commento
Unplug the wire ribbon from the motherboard.
  • Unplug the wire ribbon from the motherboard.
Aggiungi Commento
Remove all 4 PH(00) screws, this will loosen the lens from the motherboard. Remove all 4 PH(00) screws, this will loosen the lens from the motherboard.
  • Remove all 4 PH(00) screws, this will loosen the lens from the motherboard.
Aggiungi Commento
Conclusione
Robert
Membro da: 21/01/2015
894 Reputazione
8 Guide realizzate
USF Tampa, Team 9-2, Blackwell Winter 2015 Membro di USF Tampa, Team 9-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G2
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 184
