Salta al contenuto principale
Samsung Glyde Keypad Replacement
Cosa ti serve
  1. Samsung Glyde Keypad Replacement, Battery: passo 1, immagine 1 di 1
    • Using your thumb, press down and slide the back cover away from the camera.
  2. Samsung Glyde Keypad Replacement: passo 2, immagine 1 di 1
    • Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
  3. Samsung Glyde Keypad Replacement, Keyboard: passo 3, immagine 1 di 2 Samsung Glyde Keypad Replacement, Keyboard: passo 3, immagine 2 di 2
    • Use a Phillips #00 screwdriver to remove the six 4mm screws.
  4. Samsung Glyde Keypad Replacement: passo 4, immagine 1 di 2 Samsung Glyde Keypad Replacement: passo 4, immagine 2 di 2
    • Find a gap on the top side of the phone and pry apart the phone case using the plastic opening tool . Use moderate pressure to slowly maneuver around until the case is pryed apart.
    • Take the case off with your fingers
  5. Samsung Glyde Keypad Replacement: passo 5, immagine 1 di 2 Samsung Glyde Keypad Replacement: passo 5, immagine 2 di 2
    • The green film is located above the camera. It is the camera connector to the motherboard.
    • Disconnect the camera connector with the plastic opening tool.
  6. Samsung Glyde Keypad Replacement: passo 6, immagine 1 di 2 Samsung Glyde Keypad Replacement: passo 6, immagine 2 di 2
    • Take a close up of the picture for this step for a better view.
    • Use a plastic opening tool to disconnect the keyboard connector.
  7. Samsung Glyde Keypad Replacement: passo 7, immagine 1 di 2 Samsung Glyde Keypad Replacement: passo 7, immagine 2 di 2
    • The motherboard is held in place by the circular connector.
    • Using a plastic opening tool, disconnect the circular connector.
  8. Samsung Glyde Keypad Replacement: passo 8, immagine 1 di 3 Samsung Glyde Keypad Replacement: passo 8, immagine 2 di 3 Samsung Glyde Keypad Replacement: passo 8, immagine 3 di 3
    • A LCD connector is located underneath the motherboard.
    • Lift the far edge of the motherboard gently upwards toward the center.
    • Using a plastic opening tool, disconnect the LCD connector.
  9. Samsung Glyde Keypad Replacement: passo 9, immagine 1 di 2 Samsung Glyde Keypad Replacement: passo 9, immagine 2 di 2
    • Lift the motherboard up with your fingers.
    • Place the motherboard in a secure area.
  10. Samsung Glyde Keypad Replacement: passo 10, immagine 1 di 3 Samsung Glyde Keypad Replacement: passo 10, immagine 2 di 3 Samsung Glyde Keypad Replacement: passo 10, immagine 3 di 3
    • Look for the antenna which is located at the bottom end of the device. Prop the antenna out by using the plastic opening tool and slipping the tip of the tool into the edges of the antenna.
    • Using the plastic opening tool, disconnect the connector that leads from the phone to the antenna.
    • With your hands finish prying apart the antenna by lifting it up.
  11. Samsung Glyde Keypad Replacement: passo 11, immagine 1 di 2 Samsung Glyde Keypad Replacement: passo 11, immagine 2 di 2
    • The keyboard chip is located on top of the device. Pry the keyboard off of the case with the plastic opening tool.
  12. Samsung Glyde Keypad Replacement, Keypad: passo 12, immagine 1 di 2 Samsung Glyde Keypad Replacement, Keypad: passo 12, immagine 2 di 2
    • To remove the keypad, slide out the display, and poke the keypad out.
Conclusione
Jimmy La
Membro da: 10/12/11
56 Reputazione
1 Guida realizzata
Cal Poly, Team 3-12, Regan Fall 2011 Membro di Cal Poly, Team 3-12, Regan Fall 2011
CPSU-REGAN-F11S3G12
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 975
