Introduzione
The motherboard of the Fit is hidden deep insde the device, but once it's revealed, removal is just a matter of disconnecting a few ribbon cables.
Place your thumbs on the ends of the screen. Push the watch outward while pulling the band away from the watch.
  • Place your thumbs on the ends of the screen.
  • Push the watch outward while pulling the band away from the watch.
Aggiungi Commento
Heating the device with a hair dryer may warp the screen or damage the device.  It it preferable to use an iOpener for this step.
  • Heating the device with a hair dryer may warp the screen or damage the device. It it preferable to use an iOpener for this step.
  • For step-by-step instructions on using an iOpener, see the iOpener Instructions.
  • Use a hair dryer, heat gun, or an iOpener to heat the Gear Fit for 1-2 minutes until it is hot to the touch.
Aggiungi Commento
The screen is connected to the device by a ribbon cable on the left side with the power button facing you. Do not try to completely separate the screen from the device yet, and be careful. Gently pry the screen loose using a plastic opening tool. If the screen doesn't easily come loose, more heating may be required
  • The screen is connected to the device by a ribbon cable on the left side with the power button facing you. Do not try to completely separate the screen from the device yet, and be careful.
  • Gently pry the screen loose using a plastic opening tool.
  • If the screen doesn't easily come loose, more heating may be required
Aggiungi Commento
Using tweezers as a lever, pry the inner assembly out of the external casing. This will be harder than removing the screen.  Moderate force may be required. This will be harder than removing the screen.  Moderate force may be required.
  • Using tweezers as a lever, pry the inner assembly out of the external casing.
  • This will be harder than removing the screen. Moderate force may be required.
Aggiungi Commento
Disconnect the ribbon cables connecting the screen to the motherboard by lifting their metal connectors up off of the board with tweezers. Disconnect the ribbon cables connecting the screen to the motherboard by lifting their metal connectors up off of the board with tweezers. Disconnect the ribbon cables connecting the screen to the motherboard by lifting their metal connectors up off of the board with tweezers.
  • Disconnect the ribbon cables connecting the screen to the motherboard by lifting their metal connectors up off of the board with tweezers.
Aggiungi Commento
Gently peel the screen assembly up and away from the device using tweezers. Gently peel the screen assembly up and away from the device using tweezers.
  • Gently peel the screen assembly up and away from the device using tweezers.
gear fit 2 screen assembly is very expensive at the moment at 135 USD + 10USD shipping… looks like you are buying a whole new unit, ridiculous… i am planning to buy a new GF2 and have my defective GF2 to be source of spare parts in the future ( battery, hear rate sensor, circuit board, etc..) or maybe wait some time till prices go down.
ray floyd - Replica
Three ribbon cables hold the motherboard to the rest of the assembly. The battery cable in the front. When reassembling the device, make sure the battery cable is securely connected.  Moderate force may be required to push it in all the way.
  • Three ribbon cables hold the motherboard to the rest of the assembly.
  • The battery cable in the front.
  • When reassembling the device, make sure the battery cable is securely connected. Moderate force may be required to push it in all the way.
  • And two on the side.
  • Using a pair of tweezers, carefully pull each connector away to disconnect it from the rest of the assembly.
Aggiungi Commento
The motherboard is a segmented three piece construction. Use tweezers to first lift up, with a moderate amount of force, and free each ends of the motherboard from the assembly.
  • The motherboard is a segmented three piece construction.
  • Use tweezers to first lift up, with a moderate amount of force, and free each ends of the motherboard from the assembly.
  • Be sure to use ESD safe tweezers to prevent static discharge from zapping your device.
Aggiungi Commento
The motherboard should now be removable from the assembly.
  • The motherboard should now be removable from the assembly.
  • Use tweezers to lightly pry, lift, and remove the board by its middle section.
  • If the motherboard is stuck it may be caught on the assembly. Wiggle it around to free it. You may also need to pull the edges of the assembly away from the motherboard to create space.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Nathan Powell
Membro da: 24/04/2014
1.236 Reputazione
3 Guide realizzate
Cal Poly, Team 11-49, Amido Spring 2014 Membro di Cal Poly, Team 11-49, Amido Spring 2014
CPSU-AMIDO-S14S11G49
4 Membri
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 53
Tutti i Tempi: 2,591
