Introduzione
The motherboard controls a majority of the functions on your phone. Go ahead and dive into this guide for detailed steps on how to remove the motherboard on your device.
Place phone face down. Ensure the side with the display screen is not facing you. Locate battery door and slide open. Remove battery.
  • Place phone face down. Ensure the side with the display screen is not facing you.
  • Locate battery door and slide open.
  • Remove battery.
Aggiungi Commento
Remove the 7 Phillips 3.93 mm labeled screws by using the Phillips #00 Precision Screwdriver.
  • Remove the 7 Phillips 3.93 mm labeled screws by using the Phillips #00 Precision Screwdriver.
Aggiungi Commento
Use the plastic opening tool to pry open the back cover.
  • Use the plastic opening tool to pry open the back cover.
  • Insert the tool into the SD card slot and pry around the entire phone.
Aggiungi Commento
Remove one Phillips 3.93 mm screw from bottom center of the phone.
  • Remove one Phillips 3.93 mm screw from bottom center of the phone.
Aggiungi Commento
Carefully disconnect 3 ribbons at the shown location. To remove, place tool under the ribbon and pull slowly to avoid tearing. Carefully disconnect 3 ribbons at the shown location. To remove, place tool under the ribbon and pull slowly to avoid tearing. Carefully disconnect 3 ribbons at the shown location. To remove, place tool under the ribbon and pull slowly to avoid tearing.
  • Carefully disconnect 3 ribbons at the shown location. To remove, place tool under the ribbon and pull slowly to avoid tearing.
Aggiungi Commento
Pull the motherboard back and out to the left. Make sure the motherboard is faced straight up, as shown in the photo. Place your tool under the labeled area and pull gently to detach the ribbon cable from the motherboard.
  • Pull the motherboard back and out to the left. Make sure the motherboard is faced straight up, as shown in the photo.
  • Place your tool under the labeled area and pull gently to detach the ribbon cable from the motherboard.
  • At this point the motherboard should be completely detached from the rest of the phone.
Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Zhao
Membro da: 23/09/2014
115 Reputazione
2 Guide realizzate
USF Tampa, Team 15-3, Remmell Fall 2014 Membro di USF Tampa, Team 15-3, Remmell Fall 2014
USFT-REMMELL-F14S15G3
4 Membri
3 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 943
