Salta al contenuto principale
Samsung Galaxy Tab S3 Rear Facing Camera Camera Replacement
Cosa ti serve
  1. Samsung Galaxy Tab S3 Rear Facing Camera Camera Replacement, Display: passo 1, immagine 1 di 1
    • To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
    • Leave the iOpener on edge for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
  2. Samsung Galaxy Tab S3 Rear Facing Camera Camera Replacement: passo 2, immagine 1 di 1
    • Place a suction cup near edge that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
    • Use an opening tool to split apart the glass panel from the midframe.
    • Be careful to not break the glass when prying from the frame.
  3. Samsung Galaxy Tab S3 Rear Facing Camera Camera Replacement: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    Compra
    • As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
    • You can also use multiple opening picks instead of a plastic card.
  4. Samsung Galaxy Tab S3 Rear Facing Camera Camera Replacement: passo 4, immagine 1 di 3 Samsung Galaxy Tab S3 Rear Facing Camera Camera Replacement: passo 4, immagine 2 di 3 Samsung Galaxy Tab S3 Rear Facing Camera Camera Replacement: passo 4, immagine 3 di 3
    • Pull off the glass panel using the suction cup.
    • As you remove the glass panel, be careful not to tear the ribbon connecting the motherboard to the display.
    • Carefully disconnect the ribbon cable connecting the display assembly to the motherboard. You can disconnect this ribbon from either end.
  5. Samsung Galaxy Tab S3 Rear Facing Camera Camera Replacement, Rear glass panel: passo 5, immagine 1 di 2 Samsung Galaxy Tab S3 Rear Facing Camera Camera Replacement, Rear glass panel: passo 5, immagine 2 di 2
    • Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
  6. Samsung Galaxy Tab S3 Rear Facing Camera Camera Replacement, Battery: passo 6, immagine 1 di 2 Samsung Galaxy Tab S3 Rear Facing Camera Camera Replacement, Battery: passo 6, immagine 2 di 2
    • Use a Phillips #000 screwdriver to unscrew the five screws securing the battery, and the twenty-two screws surrounding the midframe.
  7. Samsung Galaxy Tab S3 Rear Facing Camera Camera Replacement: passo 7, immagine 1 di 1
    • The midframe should snap off from the device’s motherboard.
  8. Samsung Galaxy Tab S3 Rear Facing Camera Camera Replacement: passo 8, immagine 1 di 3 Samsung Galaxy Tab S3 Rear Facing Camera Camera Replacement: passo 8, immagine 2 di 3 Samsung Galaxy Tab S3 Rear Facing Camera Camera Replacement: passo 8, immagine 3 di 3
    • Locate the ribbon running from the midframe and disconnect it from the motherboard with the flat end of a spudger.
  9. Samsung Galaxy Tab S3 Rear Facing Camera Camera Replacement: passo 9, immagine 1 di 2 Samsung Galaxy Tab S3 Rear Facing Camera Camera Replacement: passo 9, immagine 2 di 2
    • Use the flat end of the spudger to pop off the connector between the battery and the motherboard.
  10. Samsung Galaxy Tab S3 Rear Facing Camera Camera Replacement: passo 10, immagine 1 di 2 Samsung Galaxy Tab S3 Rear Facing Camera Camera Replacement: passo 10, immagine 2 di 2
    • Flip the midframe over and pop the battery out, making sure to slide it out from underneath the ribbon cables.
  11. Samsung Galaxy Tab S3 Rear Facing Camera Camera Replacement: passo 11, immagine 1 di 1
    • The battery should now be removed and detached from the device.
  12. Samsung Galaxy Tab S3 Rear Facing Camera Camera Replacement, Rear Facing Camera: passo 12, immagine 1 di 3 Samsung Galaxy Tab S3 Rear Facing Camera Camera Replacement, Rear Facing Camera: passo 12, immagine 2 di 3 Samsung Galaxy Tab S3 Rear Facing Camera Camera Replacement, Rear Facing Camera: passo 12, immagine 3 di 3
    • Flip over the device, and carefully push the Rear Camera out of its framing using the spudger.
  13. Samsung Galaxy Tab S3 Rear Facing Camera Camera Replacement: passo 13, immagine 1 di 3 Samsung Galaxy Tab S3 Rear Facing Camera Camera Replacement: passo 13, immagine 2 di 3 Samsung Galaxy Tab S3 Rear Facing Camera Camera Replacement: passo 13, immagine 3 di 3
    • Flip the motherboard over and locate the ribbon attaching the Rear Camera to the motherboard. Carefully pop off the ribbon from the logic board with the flat end of the spudger.
  14. Samsung Galaxy Tab S3 Rear Facing Camera Camera Replacement: passo 14, immagine 1 di 1
    • Remove the Rear Camera from the device.
Conclusione
To reassemble your device, follow these instructions in reverse order. If you have removed too much adhesive, you may need to apply more during the reassembly process.
Altre 2 persone hanno completato questa guida.
Mimi Fucini
Membro da: 04/18/18
684 Reputazione
4 Guide realizzate
Cal Poly, Team S22-G4, Maness Spring 2018 Membro di Cal Poly, Team S22-G4, Maness Spring 2018
CPSU-MANESS-S18S22G4
5 Membri
15 Guide realizzate
Un commento
This repair can be done without removing the screen!
hansderaedt - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 11
Tutti i Tempi: 691
