Insert a plastic opening tool between the back cover and screen of the Samsung Galaxy Tab 8.9 (as indicated in the photograph).
  • Insert a plastic opening tool between the back cover and screen of the Samsung Galaxy Tab 8.9 (as indicated in the photograph).
Aggiungi Commento
Insert a second plastic opening tool 6 cm (~2.4 inches) away from the first tool.
  • Insert a second plastic opening tool 6 cm (~2.4 inches) away from the first tool.
Aggiungi Commento
Slide the second plastic opening tool along the edge of the device to separate the back cover.
  • Slide the second plastic opening tool along the edge of the device to separate the back cover.
Aggiungi Commento
Using your hands, remove the back cover.
  • Using your hands, remove the back cover.
Aggiungi Commento
Locate the motherboard and 5 connectors on it. Pry up and detach the connector from the motherboard using the flat edge of the spudger. Repeat for the 4 remaining connectors.
  • Locate the motherboard and 5 connectors on it.
  • Pry up and detach the connector from the motherboard using the flat edge of the spudger.
  • Repeat for the 4 remaining connectors.
Aggiungi Commento
Using the Phillips #00 screwdriver, unscrew the 3 screws  (1mm)  that are located near: Camera Power and volume buttons
  • Using the Phillips #00 screwdriver, unscrew the 3 screws (1mm) that are located near:
    • Camera
    • Power and volume buttons
    • Tilt sensor
Aggiungi Commento
Using the flat edge of the spudger, pry and lift up the motherboard. Using the flat edge of the spudger, pry and lift up the motherboard. Using the flat edge of the spudger, pry and lift up the motherboard.
  • Using the flat edge of the spudger, pry and lift up the motherboard.
Aggiungi Commento
Pull away the motherboard from the housing. Pull away the motherboard from the housing.
  • Pull away the motherboard from the housing.
Aggiungi Commento
After removing motherboard from device, flip motherboard over.
  • After removing motherboard from device, flip motherboard over.
Aggiungi Commento
Camera is located in the center of motherboard.
  • Camera is located in the center of motherboard.
Aggiungi Commento
Using flat side of Spudger, lift orange tab connecting the flex ribbon of the camera to the motherboard. Using flat side of Spudger, lift orange tab connecting the flex ribbon of the camera to the motherboard. Using flat side of Spudger, lift orange tab connecting the flex ribbon of the camera to the motherboard.
  • Using flat side of Spudger, lift orange tab connecting the flex ribbon of the camera to the motherboard.
Aggiungi Commento
Remove the camera from the motherboard. Remove the camera from the motherboard.
  • Remove the camera from the motherboard.
Aggiungi Commento
Conclusione
Aleezee True
Membro da: 30/09/2014
511 Reputazione
3 Guide realizzate
USF Tampa, Team 11-4, Blackwell Fall 2014 Membro di USF Tampa, Team 11-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G4
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 204
