Using the prying tool, pry the silver binding from around tablet from glass edge. You will need to go around the device several times applying some force before it comes off. Using the prying tool, pry the silver binding from around tablet from glass edge. You will need to go around the device several times applying some force before it comes off. Using the prying tool, pry the silver binding from around tablet from glass edge. You will need to go around the device several times applying some force before it comes off.
  • Using the prying tool, pry the silver binding from around tablet from glass edge. You will need to go around the device several times applying some force before it comes off.
Aggiungi Commento
Detach the ribbon cable.
  • Detach the ribbon cable.
Aggiungi Commento
Disconnect the thin connector wire. Note the position both ends go to. There is a similar connection at one end of the wire that could be confused for the correct connection. Incorrectly reconnecting the wire upon re-assembly to this terminal will result in a malfunctioning unit! Disconnect the thin connector wire. Note the position both ends go to. There is a similar connection at one end of the wire that could be confused for the correct connection. Incorrectly reconnecting the wire upon re-assembly to this terminal will result in a malfunctioning unit!
  • Disconnect the thin connector wire. Note the position both ends go to. There is a similar connection at one end of the wire that could be confused for the correct connection. Incorrectly reconnecting the wire upon re-assembly to this terminal will result in a malfunctioning unit!
Aggiungi Commento
Remove the 4 screws securing the motherboard. Remove the 4 screws securing the motherboard. Remove the 4 screws securing the motherboard.
  • Remove the 4 screws securing the motherboard.
Aggiungi Commento
Replace the original motherboard with the new circuit board. Replace the original motherboard with the new circuit board.
  • Replace the original motherboard with the new circuit board.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Stephanie Wong
Membro da: 26/09/2014
892 Reputazione
5 Guide realizzate
USF Tampa, Team 13-2, Staggers Fall 2014 Membro di USF Tampa, Team 13-2, Staggers Fall 2014
USFT-STAGGERS-F14S13G2
4 Membri
5 Guide realizzate
Thanks for this post.
But, that was the speaker module and docking port assembly, not the motherboard!
The title is misleading!
valuesphilippines - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 34
Tutti i Tempi: 2,463
