Salta al contenuto principale
Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement
Cosa ti serve
Panoramica Video
  1. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Display Assembly - Touch screen & LCD Display: passo 1, immagine 1 di 3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Display Assembly - Touch screen & LCD Display: passo 1, immagine 2 di 3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Display Assembly - Touch screen & LCD Display: passo 1, immagine 3 di 3
    • Put the scotch tape in order not to scatter pieces of glass.
    • Remove any memory card and SIM card (if the tablet is 3G version).
  2. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Battery / Back Cover: passo 2, immagine 1 di 3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Battery / Back Cover: passo 2, immagine 2 di 3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Battery / Back Cover: passo 2, immagine 3 di 3
    • Using plastic tools remove the back / battery cover.
    • Be careful with the Power and Volume buttons.
  3. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: passo 3, immagine 1 di 1
    • Before doing anything, disconnect the battery.
  4. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Micro USB Charging Port / Dock with Flex Cable: passo 4, immagine 1 di 3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Micro USB Charging Port / Dock with Flex Cable: passo 4, immagine 2 di 3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Micro USB Charging Port / Dock with Flex Cable: passo 4, immagine 3 di 3
    • This step is only if you want to replace the micro USB port flex cable.
    • Remove the two screws and disconnect the charging port flex cable from the main board.
    • Use a plastic tool to unstick the flex cable from the middle frame.
  5. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Battery: passo 5, immagine 1 di 3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Battery: passo 5, immagine 2 di 3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Battery: passo 5, immagine 3 di 3
    • This step is for only if you want to change the battery.
    • The battery is stuck to the middle panel.
    • Use the white sticker to remove it.
  6. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Components 1: passo 6, immagine 1 di 3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Components 1: passo 6, immagine 2 di 3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Components 1: passo 6, immagine 3 di 3
    • 2x loudspeackers
    • Power & Volume buttons flex cable
    • Audio jack flex cable
  7. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Components 2: passo 7, immagine 1 di 2 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement, Components 2: passo 7, immagine 2 di 2
    • Front camera
    • Wi-Fi antenna
  8. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: passo 8, immagine 1 di 3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: passo 8, immagine 2 di 3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: passo 8, immagine 3 di 3
    • Use a heat gun or hair dryer and warm the touch screen glass. This will make the adhesive more flexible and the separation easier.
    • Use a gloves to avoid any injurys from glass.
    • Do not rush.
  9. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: passo 9, immagine 1 di 3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: passo 9, immagine 2 di 3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: passo 9, immagine 3 di 3
    • Beware for the menu buttons flex cable.
  10. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: passo 10, immagine 1 di 2 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: passo 10, immagine 2 di 2
    • Always test the new spare part before final installation.
  11. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: passo 11, immagine 1 di 3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: passo 11, immagine 2 di 3 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: passo 11, immagine 3 di 3
    • Transfer the black tape from the old display. It keeps the distance the display from the battery and protects it from overheat.
    • If the adhesive tape is not in good condition you must install a new one.
  12. Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: passo 12, immagine 1 di 2 Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement: passo 12, immagine 2 di 2
    • Start with reassembling.
    • Did you do it successfully.
Conclusione
Altre 18 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
191.341 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.540 Guide realizzate
Un commento
Awesome guide, was so easy to replace complete LCD digitiser and glass all in one unit.
capinneemo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 38
Tutti i Tempi: 25,191
