Salta al contenuto principale
Samsung Galaxy Tab 3 8.0 Charging Port Replacement
Cosa ti serve
  1. Samsung Galaxy Tab 3 8.0 Charging Port Replacement, Battery - Open up the tablet: passo 1, immagine 1 di 2 Samsung Galaxy Tab 3 8.0 Charging Port Replacement, Battery - Open up the tablet: passo 1, immagine 2 di 2
    • Start out by separating the screen from the back cover using the larger plastic opening tool to pry them apart.
    • Be careful when removing the screen as negligence can cause damage.
  2. Samsung Galaxy Tab 3 8.0 Charging Port Replacement, Remove Back Cover: passo 2, immagine 1 di 2 Samsung Galaxy Tab 3 8.0 Charging Port Replacement, Remove Back Cover: passo 2, immagine 2 di 2
    • Once every part of the screen is separated from the back cover, you should be able to fully remove it with your hands.
  3. Samsung Galaxy Tab 3 8.0 Charging Port Replacement, Disconnect Battery: passo 3, immagine 1 di 2 Samsung Galaxy Tab 3 8.0 Charging Port Replacement, Disconnect Battery: passo 3, immagine 2 di 2
    • To remove the battery you must use something small, such as tweezers, to disconnect the battery from its port.
    • Note: the connection lifts up to remove.
  4. Samsung Galaxy Tab 3 8.0 Charging Port Replacement, Remove Battery: passo 4, immagine 1 di 1
    • After the battery is disconnected, use the pulling tab to safely remove the battery.
  5. Samsung Galaxy Tab 3 8.0 Charging Port Replacement, Unscrew Charging Port: passo 5, immagine 1 di 3 Samsung Galaxy Tab 3 8.0 Charging Port Replacement, Unscrew Charging Port: passo 5, immagine 2 di 3 Samsung Galaxy Tab 3 8.0 Charging Port Replacement, Unscrew Charging Port: passo 5, immagine 3 di 3
    • Unscrew the 2.9mm screws from the charging port with Phillips Head #000 and use the spudger to pry it up from under the port to remove component from the device.
Conclusione
Altre 57 persone hanno completato questa guida.
Peter Paoletta
Membro da: 09/22/14
2.085 Reputazione
3 Guide realizzate
USF Tampa, Team 4-2, Brown Fall 2014 Membro di USF Tampa, Team 4-2, Brown Fall 2014
USFT-BROWN-F14S4G2
3 Membri
26 Guide realizzate
11 Commenti
No need to remove the battery. You don't even need to unplug it, but be sure if you don't unplug it that the battery doesn't have a charge left.
Danyf - Replica
My tablet had a plastic frame around the sides and bottom under the back which was impossible to get around. I had to cut off the section covering the battery charging port in order to get the old one out and put the new one in. but it seems fine and charges well and I'm really pleased I could fix my son's tablet without spending a lot of money.
Sasha Boucher - Replica
Very easy repair. Thanks very much!
soccer123 - Replica
Hey Danyf, Lithium Ion Batteries should never go fully dead. Your tablet is going to shut down before the battery goes fully dead. I would at-least unplug it to make sure you don't short out the battery, or fry the motherboard.
Randall Vonderbrink - Replica
Hi All, just wanted ask a few questions regarding charging of Samsung galaxy 10.1 note.
I have recently changed a battery. In the start it was charging but now it's not? Do we have to reinstall drivers in android OS?
Seth Amaratunga - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 77
Tutti i Tempi: 111,286
