Introduzione
In this guide, you will learn how to replace the LED flash light on your Samsung Galaxy Tab 10.1. Having a malfunctioning flash can lead to poor lighting in the pictures taken on the tablet. There are a couple prerequisites we need to get out of the way first!
Place the bottom of the tablet towards you. Remove the two 4.1 mm screws near the charge port with a Tri-Wing screwdriver.
  • Place the bottom of the tablet towards you.
  • Remove the two 4.1 mm screws near the charge port with a Tri-Wing screwdriver.
    • On model GT-P7500, this step is omitted, as that model doesn't have these 2 screws.
Access denied! The screws near the port are covered by buttons. I wedged a pointed screw and hammered "gently" until they popped out. Problem solved!
Daniella - Replica
My model doesn't have any screws!
Barry - Replica
What can I do if my model DOESN'T HAVE ANY SCREWS? It has a loose LCD cable so SOME of my colours are all mixed up. This is really frustrating so please help
Janine Coetzee - Replica
I have SG Tab Pro 10.1
There are no screws..... now what?
iloveto travel - Replica
Great instructions! Easy to follow.
skritzberger - Replica
My model has no screws.
Faith Odutola - Replica
My model has no screws and doesn't look like the one pictured here. It's a model SM-T580.
Elsa Kramer - Replica
Be careful removing the two screw plugs by the 30 pin connector. They are easy to scratch. I couldn’t get the plugs out with my tool kit and finally removed them with the point of an exacto knife.
Behind the two plugs are sticky pads that will need to be handled carefully and saved for reassembly.
If you order a tool kit online, be sure it has a Y1 tri-wing screwdriver. The one in my kit was not Y1 and would not remove the screws.
I had to order a new screwdriver.
George Tomlinson - Replica
I don't see any screws I have a galaxy tab 4
Tammylynn Gmarter - Replica
if your model doesn’t have these screws, it’s probably ok to just skip this step. at least that’s what i did on model gt-p7500, and that repair was successful (battery replacement). Janine, a friend asked me to fix his Tab where that had happened when he tried to replace the battery himself… i just took out the 3 big cables over the battery, and re-inserted them, and that fixed the problem. you should try that if you haven’t already..
divinity76 - Replica
Start in the middle of the left side and insert a plastic opening tool between the rear panel and the front panel assembly. Carefully run the plastic opening tool along the left and top edge to pry the rear panel away from the rest of the device. Place opening picks along the side you have already pried open to keep the back panel detached from the rest of the device.
  • Start in the middle of the left side and insert a plastic opening tool between the rear panel and the front panel assembly.
  • Carefully run the plastic opening tool along the left and top edge to pry the rear panel away from the rest of the device.
  • Place opening picks along the side you have already pried open to keep the back panel detached from the rest of the device.
  • Be sure to work carefully, as prying too firmly can crack the screen.
Aggiungi Commento
Using the plastic opening tools, continue to carefully run along the right and bottom edge, and then lift the screen from the back panel. Using the plastic opening tools, continue to carefully run along the right and bottom edge, and then lift the screen from the back panel. Using the plastic opening tools, continue to carefully run along the right and bottom edge, and then lift the screen from the back panel.
  • Using the plastic opening tools, continue to carefully run along the right and bottom edge, and then lift the screen from the back panel.
Aggiungi Commento
Flip up the retaining flaps on the ZIF connectors that secure the three large ribbon cables. Carefully pull the three ribbon cables from their sockets on the motherboard. Carefully pull the three ribbon cables from their sockets on the motherboard.
  • Flip up the retaining flaps on the ZIF connectors that secure the three large ribbon cables.
  • Carefully pull the three ribbon cables from their sockets on the motherboard.
Looking at the ZIF connectors in step 4....mine isn't charging. I suspect the problem lies in the jack for the USB/power cable. Would I be correct in thinking it's a matter of following to this point, then replacing the internal cable?
gzapiec - Replica
I took the cable all the way off and can't get on what to
I have sound but no pictures/screen what did I do wrong what should I check?
Rodney perini - Replica
Remove the ten 3 mm Phillips #00 screws surrounding the battery. Remove the ten 3 mm Phillips #00 screws surrounding the battery.
  • Remove the ten 3 mm Phillips #00 screws surrounding the battery.
Aggiungi Commento
Lift the edge of the battery up with your finger or a spudger. Detach the battery by holding the motherboard down while gently lifting the battery up. Detach the battery by holding the motherboard down while gently lifting the battery up.
  • Lift the edge of the battery up with your finger or a spudger.
  • Detach the battery by holding the motherboard down while gently lifting the battery up.
Very simple, clever and effective presentation of opening rear cover.Thanks very much for simplicity. The way presented is user friendly.
Video presentation is mostly in dark ambient, it is useless. Once moore thank you very much.
Ljubo Baricevic - Replica
The battery connector lifts up, not back. A plastic tool lifting under the five wires from the battery right at the base of the connector helps.
petermui - Replica
then what where do you buy a battery
Janie montemayor - Replica
ok after its all apart where do i buy the battery
@janiemontemayor Sorry about that—the link for the replacement battery was out of date. It's fixed now! Try the link at the top of this guide.
Jeff Suovanen -
Welches Tablet hast du denn da? Mein 10.1 hat keine Schrauben an der Ladebuchse
Anja Mickenbecker - Replica
Use your spudger to gently pry up the black connection of the LED flash from the motherboard. Use your spudger to gently pry up the black connection of the LED flash from the motherboard.
  • Use your spudger to gently pry up the black connection of the LED flash from the motherboard.
Aggiungi Commento
Grab the black connection with your fingers and lift it up from its slot. We have removed the motherboard in these pictures to make it easier to see, but it is not necessary to complete this  step. We have removed the motherboard in these pictures to make it easier to see, but it is not necessary to complete this  step.
  • Grab the black connection with your fingers and lift it up from its slot.
  • We have removed the motherboard in these pictures to make it easier to see, but it is not necessary to complete this step.
Aggiungi Commento
Conclusione
Davie Sy
Membro da: 30/09/2013
1.208 Reputazione
11 Guide realizzate
Cal Poly, Team 13-5, Forte Fall 2013 Membro di Cal Poly, Team 13-5, Forte Fall 2013
CPSU-FORTE-F13S13G5
5 Membri
17 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 25
Tutti i Tempi: 6,078
