Salta al contenuto principale
Samsung Galaxy SIII Mini VE Power Button Replacement
Cosa ti serve
  1. Samsung Galaxy SIII Mini VE Power Button Replacement, Removing Rear Casing: passo 1, immagine 1 di 3 Samsung Galaxy SIII Mini VE Power Button Replacement, Removing Rear Casing: passo 1, immagine 2 di 3 Samsung Galaxy SIII Mini VE Power Button Replacement, Removing Rear Casing: passo 1, immagine 3 di 3
    • Flip your phone so you are facing the back.
    • Locate the notch at the top and gently use your finger or an opening tool to remove the rear casing.
  2. Samsung Galaxy SIII Mini VE Power Button Replacement, Removing Battery: passo 2, immagine 1 di 2 Samsung Galaxy SIII Mini VE Power Button Replacement, Removing Battery: passo 2, immagine 2 di 2
    • Use your finger or an opening tool to pry the battery out of the phone.
  3. Samsung Galaxy SIII Mini VE Power Button Replacement, Removing Screws: passo 3, immagine 1 di 1
    • Use the Phillips #000 Screwdriver to remove the 10, 4mm screws holding the plastic frame in place.
  4. Samsung Galaxy SIII Mini VE Power Button Replacement: passo 4, immagine 1 di 2 Samsung Galaxy SIII Mini VE Power Button Replacement: passo 4, immagine 2 di 2
    • Using an opening tool, gently separate the plastic framing from the phone.
  5. Samsung Galaxy SIII Mini VE Power Button Replacement, Removing Circuit Board: passo 5, immagine 1 di 3 Samsung Galaxy SIII Mini VE Power Button Replacement, Removing Circuit Board: passo 5, immagine 2 di 3 Samsung Galaxy SIII Mini VE Power Button Replacement, Removing Circuit Board: passo 5, immagine 3 di 3
    • Unhook the two electrical connections at the bottom of the phone using your fingernail or a spudger.
    • Next, use the spudger and tweezers to remove the speaker at the top of the phone.
    • Once the 3 components have detached, the circuit board should release from the phone except for 1 connection on the underside.
    • Detach this connection using the spudger.
  6. Samsung Galaxy SIII Mini VE Power Button Replacement, Power Button: passo 6, immagine 1 di 2 Samsung Galaxy SIII Mini VE Power Button Replacement, Power Button: passo 6, immagine 2 di 2
    • The power button is connected by two plastic posts, simply lift the button away from the phone using your fingers.
Conclusione
Altre 5 persone hanno completato questa guida.
Megan
Membro da: 10/23/14
1.186 Reputazione
6 Guide realizzate
Michigan Tech, Team 1-8, Lauer Fall 2014 Membro di Michigan Tech, Team 1-8, Lauer Fall 2014
MTU-LAUER-F14S1G8
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 3,774
