Salta al contenuto principale
Samsung Galaxy S6 Camera Lens Glass Replacement
Cosa ti serve
Panoramica Video
  1. Samsung Galaxy S6 Camera Lens Glass Replacement, Camera Lens Glass: passo 1, immagine 1 di 3 Samsung Galaxy S6 Camera Lens Glass Replacement, Camera Lens Glass: passo 1, immagine 2 di 3 Samsung Galaxy S6 Camera Lens Glass Replacement, Camera Lens Glass: passo 1, immagine 3 di 3
    • Remove the back cover at first. It's a pity that we only have a S6 with broken back cover to show how to do camera lens glass replacement.
  2. Samsung Galaxy S6 Camera Lens Glass Replacement: passo 2, immagine 1 di 1
    • Please be careful when remove the back cover! It's just a little weak.
  3. Samsung Galaxy S6 Camera Lens Glass Replacement: passo 3, immagine 1 di 3 Samsung Galaxy S6 Camera Lens Glass Replacement: passo 3, immagine 2 di 3 Samsung Galaxy S6 Camera Lens Glass Replacement: passo 3, immagine 3 di 3
    • And then pry up the camera lens ring from bottom right corner. There is some adhesive underneath. Be careful and avoid scratching the metal ring with sharp tweezers.
    • At last, push the camera lens glass by your finger or with a spudger and remove it finally.
  4. Samsung Galaxy S6 Camera Lens Glass Replacement: passo 4, immagine 1 di 3 Samsung Galaxy S6 Camera Lens Glass Replacement: passo 4, immagine 2 di 3 Samsung Galaxy S6 Camera Lens Glass Replacement: passo 4, immagine 3 di 3
    • Now it's time to place the new camera lens.Peel off the upper film and assemble the glass with the ring.
  5. Samsung Galaxy S6 Camera Lens Glass Replacement: passo 5, immagine 1 di 2 Samsung Galaxy S6 Camera Lens Glass Replacement: passo 5, immagine 2 di 2
    • Peel off the bottom film and we can stick the new camera lens assembly back.
    • And one tips: you will need a piece of new back cover sticker because the old one maybe can't be used any more.
    • That's the guide to replace S6 camera glass and camera ring together.
  6. Samsung Galaxy S6 Camera Lens Glass Replacement: passo 6, immagine 1 di 1
    • If your S6 camera lens was broken heavily, just remove it directly but very carefully. Don't hurt the camera or scratch the metal ring.
  7. Samsung Galaxy S6 Camera Lens Glass Replacement: passo 7, immagine 1 di 3 Samsung Galaxy S6 Camera Lens Glass Replacement: passo 7, immagine 2 di 3 Samsung Galaxy S6 Camera Lens Glass Replacement: passo 7, immagine 3 di 3
    • Place the sticker on the camera ring at first.
  8. Samsung Galaxy S6 Camera Lens Glass Replacement: passo 8, immagine 1 di 2 Samsung Galaxy S6 Camera Lens Glass Replacement: passo 8, immagine 2 di 2
    • And then stick on the new camera glass and done the replacement.
    • That's the guide for replace S6 camera glass only.
Conclusione
Altre 54 persone hanno completato questa guida.
Sophia
Membro da: 03/25/14
43.810 Reputazione
62 Guide realizzate
27 Commenti
Is it possible to replace just the lens without taking off the back cover? Like can I just use a suction tool to pull off the broken lens and put in the new one?
Alex Sangue - Replica
Yes, that is possible!
Robin -
I am wondering the same thing. I believe it would work. Don't see the need in pulling the back cover to replace a piece of exposed glass.
4freese - Replica
Yes. It can be done. I did it using a hair dryer to warm the lens and peel if off gently, starting in one corner. If it seems reluctant to come off you may need to heat it a little more. Be careful not to damage to outer metal ring (as I did) and then replace the glass lens as described.
vicbliz - Replica
The guide for replacing a heavily broken camera lens is starting from step 6.
tkuilman1 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 78
Tutti i Tempi: 196,479
