Introduzione
The removal of the motherboard is a time consuming process. It involves the removal of most components from the phone. It also involves the use of a few tools such as a guitar pick, a heat gun, tweezers, a screwdriver, and plastic opening tools. You should be aware of the hazards and safety procedures of all tools before starting the process.
Cosa ti serve
Insert your fingernail or plastic opening tool into the divot at the top of the rear-facing camera.
Gently pry and twist the flexible rear cover off the back of the phone.
Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward.
Remove the battery away from the phone.
Use a heat gun at an approximate distance of 2-3 inches from the phone to apply heat to the phone and loosen up the adhesive in the display.
Use a Phillips 0 screwdriver to remove all 12 Phillips #0 screws.
Use your finger or a plastic opening tool to disconnect the proximity/light sensor from the motherboard.
Use tweezers to gently pull the proximity/light sensor out.
Altre 19 persone hanno completato questa guida.
