Introduzione
Use this guide to replace the speaker enclosure in your Galaxy S4. The speaker enclosure is attached to the midframe and includes both the speakerphone speaker and two antennas.
Cosa ti serve
Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Remove the microSD card.
Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
Remove the battery from your phone.
Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
Remove the SIM card.
Remove the nine 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
Hold the midframe in one hand and the speaker enclosure in the other.
Gently twist the speaker enclosure away from the midframe to pop it free from the clips securing it to the midframe.
Remove the speaker enclosure from the midframe.
Altre 39 persone hanno completato questa guida.
