Salta al contenuto principale
Samsung Galaxy S4 Active SIM Card Replacement
Cosa ti serve
  1. Samsung Galaxy S4 Active SIM Card Replacement, Rear Case: passo 1, immagine 1 di 2 Samsung Galaxy S4 Active SIM Card Replacement, Rear Case: passo 1, immagine 2 di 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Samsung Galaxy S4 Active SIM Card Replacement, Battery: passo 2, immagine 1 di 1
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward to remove it.
  3. Samsung Galaxy S4 Active SIM Card Replacement, SIM Card: passo 3, immagine 1 di 1
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the SIM card.
Conclusione
Altre 5 persone hanno completato questa guida.
Geoff Wacker
Membro da: 09/30/13
89.953 Reputazione
89 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 3,803
