Salta al contenuto principale
Samsung Galaxy S III Motherboard Replacement
Cosa ti serve
  1. Samsung Galaxy S III Motherboard Replacement, Rear Case: passo 1, immagine 1 di 2 Samsung Galaxy S III Motherboard Replacement, Rear Case: passo 1, immagine 2 di 2
    • The following four steps can be accomplished without a plastic opening tool. However, it's recommended to use a tool to best avoid breaking any clips along the perimeter of the rear case.
    • Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
    • Gently twist the opening tool to disconnect the clips securing the top of the rear case.
  2. Samsung Galaxy S III Motherboard Replacement: passo 2, immagine 1 di 2 Samsung Galaxy S III Motherboard Replacement: passo 2, immagine 2 di 2
    • Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone.
  3. Samsung Galaxy S III Motherboard Replacement: passo 3, immagine 1 di 2 Samsung Galaxy S III Motherboard Replacement: passo 3, immagine 2 di 2
    • Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case.
  4. Samsung Galaxy S III Motherboard Replacement: passo 4, immagine 1 di 2 Samsung Galaxy S III Motherboard Replacement: passo 4, immagine 2 di 2
    • Pry along the top right side, and continue prying down the right side of the rear case.
  5. Samsung Galaxy S III Motherboard Replacement: passo 5, immagine 1 di 2 Samsung Galaxy S III Motherboard Replacement: passo 5, immagine 2 di 2
    • Lift up and remove the rear case from the phone.
    • You may need to peel the case up to separate it from any clips still holding it to the bottom of the phone.
  6. Samsung Galaxy S III Motherboard Replacement, Battery: passo 6, immagine 1 di 2 Samsung Galaxy S III Motherboard Replacement, Battery: passo 6, immagine 2 di 2
    • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
    • Wedge a plastic opening tool into the small notch above the battery.
    • Pry the battery up out of its recess.
  7. Samsung Galaxy S III Motherboard Replacement: passo 7, immagine 1 di 2 Samsung Galaxy S III Motherboard Replacement: passo 7, immagine 2 di 2
    • Remove the battery.
  8. Samsung Galaxy S III Motherboard Replacement, SIM Card: passo 8, immagine 1 di 3 Samsung Galaxy S III Motherboard Replacement, SIM Card: passo 8, immagine 2 di 3 Samsung Galaxy S III Motherboard Replacement, SIM Card: passo 8, immagine 3 di 3
    • Using your fingernail, push the SIM card slightly deeper into its slot, until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the SIM card into the slot until it clicks in place.
  9. Samsung Galaxy S III Motherboard Replacement: passo 9, immagine 1 di 3 Samsung Galaxy S III Motherboard Replacement: passo 9, immagine 2 di 3 Samsung Galaxy S III Motherboard Replacement: passo 9, immagine 3 di 3
    • Use your thumb to slide enough of the SIM card out of its slot to grab ahold of it.
    • Grasp and remove the SIM card away from the phone.
  10. Samsung Galaxy S III Motherboard Replacement, microSD Card: passo 10, immagine 1 di 3 Samsung Galaxy S III Motherboard Replacement, microSD Card: passo 10, immagine 2 di 3 Samsung Galaxy S III Motherboard Replacement, microSD Card: passo 10, immagine 3 di 3
    • Using your fingernail, push the microSD card slightly deeper into its slot, until you hear a click.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  11. Samsung Galaxy S III Motherboard Replacement: passo 11, immagine 1 di 2 Samsung Galaxy S III Motherboard Replacement: passo 11, immagine 2 di 2
    • Use your thumb to slide the microSD card out of the slot.
    • Remove the microSD card from the phone.
  12. Samsung Galaxy S III Motherboard Replacement, Plastic Midframe: passo 12, immagine 1 di 1
    • Remove the ten 4.0 mm Phillips screws securing the midframe to the front panel assembly.
  13. Samsung Galaxy S III Motherboard Replacement: passo 13, immagine 1 di 2 Samsung Galaxy S III Motherboard Replacement: passo 13, immagine 2 di 2
    • Grasp the left side of the plastic midframe with your thumb and forefinger and lift it away from the phone.
    • The midframe lightly snaps in place, and can be removed with very little force.
  14. Samsung Galaxy S III Motherboard Replacement, Headphone Jack/Speaker Assembly: passo 14, immagine 1 di 2 Samsung Galaxy S III Motherboard Replacement, Headphone Jack/Speaker Assembly: passo 14, immagine 2 di 2
    • Use a plastic opening tool to pry the rear-facing camera connector up from its socket on the motherboard.
    • Make sure you are prying on the connector and not the socket, or you may damage the motherboard.
  15. Samsung Galaxy S III Motherboard Replacement: passo 15, immagine 1 di 2 Samsung Galaxy S III Motherboard Replacement: passo 15, immagine 2 di 2
    • Insert a plastic opening tool outboard of the speaker portion of the headphone jack/speaker assembly.
    • Gently pry the headphone jack/speaker assembly up from the front assembly.
  16. Samsung Galaxy S III Motherboard Replacement: passo 16, immagine 1 di 1
    • Lift the headphone jack/speaker assembly out of the Galaxy S III.
  17. Samsung Galaxy S III Motherboard Replacement, Motherboard Assembly: passo 17, immagine 1 di 1
    • Use a plastic opening tool to pry the front-facing camera connector from its socket on the motherboard.
    • Do not try to remove the front-facing camera just yet. Its cable is still routed beneath the motherboard assembly to the ambient light sensor.
  18. Samsung Galaxy S III Motherboard Replacement: passo 18, immagine 1 di 2 Samsung Galaxy S III Motherboard Replacement: passo 18, immagine 2 di 2
    • Disconnect the digitizer cable by gently prying its connector up from its socket on the motherboard.
  19. Samsung Galaxy S III Motherboard Replacement: passo 19, immagine 1 di 2 Samsung Galaxy S III Motherboard Replacement: passo 19, immagine 2 di 2
    • Disconnect the display data cable from the motherboard.
  20. Samsung Galaxy S III Motherboard Replacement: passo 20, immagine 1 di 3 Samsung Galaxy S III Motherboard Replacement: passo 20, immagine 2 di 3 Samsung Galaxy S III Motherboard Replacement: passo 20, immagine 3 di 3
    • Pry the Wi-Fi antenna cable connector up from its socket on the motherboard.
    • Gently move the cable out of the way of the motherboard.
  21. Samsung Galaxy S III Motherboard Replacement: passo 21, immagine 1 di 1
    • Remove the single 3.0 mm Phillips screw securing the motherboard to the front panel assembly.
  22. Samsung Galaxy S III Motherboard Replacement: passo 22, immagine 1 di 2 Samsung Galaxy S III Motherboard Replacement: passo 22, immagine 2 di 2
    • Carefully lift the bottom of the motherboard assembly away from the front panel assembly.
    • Remove the motherboard assembly from the front panel assembly, minding any cables that may snag on it.
  23. Samsung Galaxy S III Motherboard Replacement, Rear-Facing Camera: passo 23, immagine 1 di 2 Samsung Galaxy S III Motherboard Replacement, Rear-Facing Camera: passo 23, immagine 2 di 2
    • Flip the motherboard over. We recommend setting it on a grounded work surface.
    • Use a plastic opening tool to pry the rear-facing camera connector from its socket.
  24. Samsung Galaxy S III Motherboard Replacement: passo 24, immagine 1 di 1
    • Remove the rear-facing camera off the motherboard.
  25. Samsung Galaxy S III Motherboard Replacement, Motherboard: passo 25, immagine 1 di 1
    • The motherboard remains.
Conclusione
Altre 269 persone hanno completato questa guida.
42 Commenti
Between step 13 and 14, there should be a step to detach the cable to the camera lens and speaker assembly and the removal of the assembly.
ewu777 - Replica
Where do i buy the original motherboard and what is the cost
Mustafa Mukhtiar - Replica
I have a motherboard of samsung galaxy s3 sgh-t999 t mobile pm me here's my email tan.jeffrey84@yahoo.com for more info
Dragneel Natzu -
Cheapest place to buy them is ebay.
Tracy Smith -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 51
Tutti i Tempi: 297,109
