Introduzione
The front-facing camera is used for taking "selfies" and other pictures that the photographer will be in. If you consider yourself an avid Snapchatter or Instagramer, then it is essential to have an operating front-facing camera. The camera can be accessed without removing the motherboard and its attached to the motherboard by a clip. It can be replaced by lightly pulling on the camera to unlatch the clip.
Insert your fingernail or a plastic tool into the opening near the headphone jack on top of the phone. Gently pry apart the rear case from the midframe and remove. Gently pry apart the rear case from the midframe and remove.
  • Insert your fingernail or a plastic tool into the opening near the headphone jack on top of the phone.
  • Gently pry apart the rear case from the midframe and remove.
Aggiungi Commento
Insert your fingernail, or a plastic tool, into the crevice on the lower left side of the back side. Gently pry the battery from the back of the phone. Gently pry the battery from the back of the phone.
  • Insert your fingernail, or a plastic tool, into the crevice on the lower left side of the back side.
  • Gently pry the battery from the back of the phone.
Aggiungi Commento
With the Phillips head screwdriver, remove all seven 4.0 mm screws, highlighted in red, from the rear case. Insert your finger or an opening tool underneath the midframe and gently pry apart from the phone.
  • With the Phillips head screwdriver, remove all seven 4.0 mm screws, highlighted in red, from the rear case.
  • Insert your finger or an opening tool underneath the midframe and gently pry apart from the phone.
Aggiungi Commento
The front facing camera is located in the top right corner of the back of the phone. To remove the camera, gently pull until it detaches from the motherboard. To remove the camera, gently pull until it detaches from the motherboard.
  • The front facing camera is located in the top right corner of the back of the phone.
  • To remove the camera, gently pull until it detaches from the motherboard.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Keon Horahan
Membro da: 13/10/2014
817 Reputazione
6 Guide realizzate
Clemson, Team 3-3, Benson Fall 2014 Membro di Clemson, Team 3-3, Benson Fall 2014
CLEM-BENSON-F14S3G3
5 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 240
