Introduzione
This guide will teach you how to replace the vibration motor of the Samsung Galaxy Prevail 2. Prior knowledge of how to use a soldering iron is required.
Parti
Nessuna parte richiesta.
Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone. Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone. Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
  • Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
Aggiungi Commento
Gently pull the battery out of the phone. Gently pull the battery out of the phone. Gently pull the battery out of the phone.
  • Gently pull the battery out of the phone.
Aggiungi Commento
Unscrew all of the screws. Be sure to set the screws aside in a safe place.
  • Unscrew all of the screws.
  • Be sure to set the screws aside in a safe place.
Aggiungi Commento
Insert the plastic prying tool between the silver frame and the white face of the phone. to pry off the front frame. Make sure to pry around the entire frame to loosen it before proceeding. Use your thumbs to separate the motherboard from the back of the phone.
  • Insert the plastic prying tool between the silver frame and the white face of the phone. to pry off the front frame.
  • Make sure to pry around the entire frame to loosen it before proceeding.
  • Use your thumbs to separate the motherboard from the back of the phone.
Aggiungi Commento
With the plastic prying tool, lift up the flap in order to fully open the motherboard. With the plastic prying tool, lift up the flap in order to fully open the motherboard. With the plastic prying tool, lift up the flap in order to fully open the motherboard.
  • With the plastic prying tool, lift up the flap in order to fully open the motherboard.
Aggiungi Commento
With plastic prying tool, lift the flap up to divide the motherboard. This will make it easier to detach the internal battery. This will make it easier to detach the internal battery.
  • With plastic prying tool, lift the flap up to divide the motherboard.
  • This will make it easier to detach the internal battery.
Aggiungi Commento
With plastic prying tool, lift up the vibration motor. With plastic prying tool, lift up the vibration motor. With plastic prying tool, lift up the vibration motor.
  • With plastic prying tool, lift up the vibration motor.
Aggiungi Commento
With the soldering iron remove the solder attaching the vibration motor to the motherboard.
  • With the soldering iron remove the solder attaching the vibration motor to the motherboard.
Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Garrett Bowleg
Membro da: 08/10/2014
467 Reputazione
2 Guide realizzate
USF Tampa, Team 14-4, Leahy Fall 2014 Membro di USF Tampa, Team 14-4, Leahy Fall 2014
USFT-LEAHY-F14S14G4
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 753
