Salta al contenuto principale
Samsung Galaxy Prevail 2 Rear Facing Camera Replacement
Cosa ti serve
  1. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Removing Back Casing: passo 1, immagine 1 di 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Removing Back Casing: passo 1, immagine 2 di 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Removing Back Casing: passo 1, immagine 3 di 3
    • Using your finger nails or the spudger; pry the plastic casing open, and pull away from the body of the phone.
  2. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Battery: passo 2, immagine 1 di 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Battery: passo 2, immagine 2 di 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Battery: passo 2, immagine 3 di 3
    • Gently pull the battery out of the phone.
  3. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Screws: passo 3, immagine 1 di 2 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Remove Screws: passo 3, immagine 2 di 2
    • Unscrew all of the screws.
    • Be sure to set the screws aside in a safe place.
  4. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Pry Off Back Of Phone: passo 4, immagine 1 di 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Pry Off Back Of Phone: passo 4, immagine 2 di 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Pry Off Back Of Phone: passo 4, immagine 3 di 3
    • Insert the plastic prying tool between the silver frame and the white face of the phone to pry off the front frame.
    • Make sure to pry around the entire frame before attempting to loosen it.
    • Push the motherboard out using your thumbs as shown
  5. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Open Up The Motherboard: passo 5, immagine 1 di 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Open Up The Motherboard: passo 5, immagine 2 di 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Open Up The Motherboard: passo 5, immagine 3 di 3
    • Lift the flap up using the plastic prying tool.
  6. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Motherboard: passo 6, immagine 1 di 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Motherboard: passo 6, immagine 2 di 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Motherboard: passo 6, immagine 3 di 3
    • Lift the second flap to detach the motherboard completely.
  7. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Locate Camera: passo 7, immagine 1 di 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Locate Camera: passo 7, immagine 2 di 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Locate Camera: passo 7, immagine 3 di 3
    • With plastic prying tool, lift the flap connected to the camera (indicated in red) to remove it.
    • Be sure that you are looking at the back face of the motherboard.
  8. Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Camera: passo 8, immagine 1 di 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Camera: passo 8, immagine 2 di 3 Samsung Galaxy Prevail 2 Rear Facing Camera Replacement, Detach Camera: passo 8, immagine 3 di 3
    • Carefully lift and remove the camera from its position.
Conclusione
Altre 8 persone hanno completato questa guida.
USF Tampa, Team 14-4, Leahy Fall 2014 Membro di USF Tampa, Team 14-4, Leahy Fall 2014
USFT-LEAHY-F14S14G4
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,394
